CLICK HERE--><--CLICK HERE
K-77 prop selection on SV-11 ARF
Started by Matt Brown, March 13, 2019, 12:27:14 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Matt Brown
Hi Randy,
        I won a K-77 in a raffle last year. I wanted to build something for it but that hasn't happened and not likely to anytime this year. So I've decided to buy one of the SV-11 ARFs for it so I'd have a decent glow plane this season. I'm currently flying the electric SV-11 ARF and very happy with it. I figured you would be the best to tell me what prop to start with on it. I'd rather not start with real expensive carbon props.
Thanks, Matt
Walter Hicks
Matt I have one on the Muffler from Kaz and use a Rev Up 13x5 which has 4.5 " Pitch works  well around 8700 rpm 64 ' eyelet to eyelet lines.
Airplane is 62 oz and about 660 square inches. works well.
RandySmith
Quote from: Matt Brown on March 13, 2019, 12:27:14 PM
Hi Randy,
Thanks, Matt
Hi Matt
For  cheaper props  try a  14 x 5  wood, plastic  or  13.5 x 4.5  , You can trim the 14 inch prop down if it gives you precession problems, trim 1/4 inch at a time.  Hint  you can run a little  larger  wood props  than plastic ones
Those will get you close
