  • June 16, 2025, 02:47:46 PM
Author Topic: ST60 fuel tank  (Read 3280 times)
Offline Ron Hess Sr
ST60 fuel tank
« on: February 05, 2012, 02:44:14 PM »
Hi Randy,I have a st60 setup by you, could you tell how many oz of fuel will it take to do the pattern?it has a .181venturi if this helps and what would be a good 3blade prop for it.  Thanks for your time. Ron in indy
Re: ST60 fuel tank
« Reply #1 on: February 06, 2012, 12:57:31 PM »
Hi Ron  6 to 6.5 ounces with either 13 x 6 or 12.5 x 5 2 blades  The Magic 12.5 x 5 is very good
