  • August 01, 2025, 06:52:37 PM
Author Topic: OS LA 46 Special hand built engines  (Read 12486 times)
« on: May 29, 2017, 09:55:27 PM »
OS LA 46   NEW  Blue Smith Balanced & Blueprinted hand fitted  with heat cycled Piston sleeves  with front  PA  NVA  149.00   Engine only
OS LA 46   NEW  Silver Smith  Balanced & Blueprinted hand fitted  with heat cycled Piston sleeves with front  PA  NVA  149.00   engine only
OS LA 46  (Blue Head ) Custom built Blue head motor, silver case, metal backplate, great looking engine Balanced & Blueprinted hand fitted  with heat cycled Piston sleeves with front  PA  NVA  165.00   engine only
I stock OS parts
Tongue mufflers   19.99
Stock TT mufflers lighter than OS  and  works well on LA 40 46  special  $10.00
Offline Fredvon4
  • Central Texas
Re: OS LA 46 Special hand built engines
« Reply #1 on: May 30, 2017, 08:17:36 AM »
I would like the Silver OS B&B LA .46 and 2 of the TT mufflers
will send an e-mail
Fred
Fred von Gortler IV
« Reply #2 on: May 30, 2017, 12:21:04 PM »
will send an e-mail
Fred
OK Will get it off to you
Offline Fredvon4
  • Central Texas
« Reply #3 on: May 30, 2017, 12:36:04 PM »
Thank you sir
MT CC info has not changed since last order
Fred von Gortler IV
