  • July 31, 2025, 05:50:23 AM
Author Topic: Enya 61 CXS pro Ringed Rear Ex Model  (Read 6444 times)
Offline Stan Bidowski
    • Winnipeg Perfect Circle Flying Club
« on: April 03, 2010, 03:43:19 PM »
   Hi Randy, I'd like to know some more about this engine.  Does the Enya 61 CXS pro Ringed Rear Ex Model come with a muffler, or is one  available?
   Are there headers for it available?  What rise(s)? Do other engine headers fit the Enya?
Does it make a good piped engine?    Would the piped Enya's performance be comparible
to a PA .61 on pipe? Would an unpiped Enya's power/run be comparible to, say, an ST 60 in unpiped mode?
   The Enya website does not have a picture of the rear exhaust 61.  Can you please post some?
Are the specs different then the side exhaust version- weight, timing, etc?
Does it mount in the same holes as another engine, say an ST 60, or older model Enyas?   H^^
Stan Bidowski
MAAC 17167
Re: Enya 61 CXS pro Ringed Rear Ex Model
« Reply #1 on: April 03, 2010, 05:19:47 PM »
Stan Bidowski
Hi Stan
The new Enya 60 RE is the same basic motor as the 61 SE.
It does not come with a muffler. however Enya says they will have one soon, I have one now, I have headers 1.25 rise, and  slide on cnc Aero Tube mufflers.
the motor makes Good power and works with a muffler or pipe, I would use a pipe if I were to have one in a ship, and I may put one in a SV-11 ARC very soon, The Enya has a little more Power than a good ST60
Offline Allan Perret
  • Proverbs
« Reply #2 on: May 06, 2010, 08:04:18 AM »
Hi Stan
Hey Randy:
"The Enya has a little more Power than a good ST60"
The Enya you were testing here was it the side exhaust with muffler, or the rear exhause with pipe ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #3 on: May 07, 2010, 07:52:54 AM »
Hi
I tested and ran both of the side and rear versions
« Reply #4 on: May 09, 2010, 10:10:53 AM »
Randy, I'd like to hear more about these Enya's when you've had the chance
to use them in a plane, in the air.  A piped rear exhaust Enya 61 in a SV-11
ARF is a couple of unknowns I'd like to know more about!  This could be a
very nice combination once the correct setup is found.
Stan Bidowski
MAAC 17167
