  • July 31, 2025, 05:28:35 PM
Author Topic: New stock and NEW products Engines planes props  (Read 16465 times)
« on: October 11, 2019, 10:02:57 PM »
I have these laser cut kits in stock these are  all  VERY complete  kits, and  will  be  at the  old  price until  December
New redesign  SV-11  kist
New redesign NOVAR  kits
New Design Evolution kits
Laser  DREADNOUGHT  Kits
Laser cut Tempest ll  kits
ARF  ARC  Sv-11s  and  Vectors
more Laser cut kits  will be back in stock soon
Super Tiger  G-51  stunt  balanced  blueprinted with ABC  Gardner Piston & Liner True venturi and  PA  NVA  $299.00
Enya 61 red head  rear ex  stunt engine  NIB   275.00 I have headers and  pipes  also
Enya  45 dual ball bearing stunt version, very strong 199.00   SOLD !
Enya  Aero Product  ultra light  cnc  Tube mufflers  for  40  45  51  60,  42.95
New  Enya  50 SS  stunt version  215.00    SOLD !
Enya  25  red nose  SS - S  stunt version  ABC ( not  iron steel) 145.00
Enya 25 SS - S  stunt  iron steel  version  109.00
Magnum 36 converted  to  CL  New  189.00
Magnum 36 C/L convert   bench ran a few times, like new  159.00
Thunder Tiger  36  convert  B&B  to  cl stunt  New  189.00
Ultimate FOX 35  CNC Smith head, Balanced crank, cnc  backplate, true ABC piston sleeve, with alloy rod with bushing top and bottom, OS 15 nva, and tongue muffler, all brand  new  $ 275.00   1  left  !!
George Aldrich FOX 35  ABC  New ! $225.00
New in box  FOX 35s   stock with first gen muffler ears  99.00
SPECIAL  FOX 35 by Duke FOX, Sig Commemorative model, All BLACK  with  SIG  engraved on the side  199.00
Hand built NEW  OS  46  LA   All blue  front needle  B&B  $149.00
OS 46 LA  silver  Smith built from all  new parts from OS in Japan, B&B front intake  os needle  $149.00
OS 46  LA  same as above but with  PA  NVA  and  cnc backplate B&B  $169.00
OS LA  46  Blue head, best looking version hand built B&B with  PA NVA and  cnc Al backplate  $175.00
All OS have  replacement socket head  bolts
ST G51  lapped  ABC , NEW and  Rebuilt, plus  Rings version ,  coming  soon in small quantities
Many new  CF 2 blade  2 in spinners, Many new  Hand made  CF props, 12.2 x 4.2 , 13.3 x 4.2, 13 x 6 N  12 x 6N  , coming  the  12 x 4 N  11 x 4N thin small hub 3 blade Bolly clone
Wide cuff  under camber  11 x 5 for  Electric  or  IC, works great on  40s  46  and  51s
« Last Edit: October 24, 2019, 02:54:58 PM by RandySmith »
Offline Steve Dwyer
Re: New stock and NEW products Engines planes props
« Reply #1 on: December 06, 2020, 10:04:51 AM »
Randy, I have sent you a PM regarding the Vector 40.
