  • July 01, 2025, 08:27:50 AM
Author Topic: Tongue Muffler, Venturi & Needle Assembly for .10/.15?  (Read 5294 times)
Dennis Leonhardi
« on: April 09, 2010, 04:01:51 PM »
Randy, can you supply any of the above for Magnum, OS Max or Thunder Tiger .10 or .15 engines?
Thanks!
Dennis
Re: Tongue Muffler, Venturi & Needle Assembly for .10/.15?
« Reply #1 on: April 10, 2010, 01:33:58 PM »
Thanks!
Dennis
Hi Dennis
I am sure I can do some of them, I will check and get back to you, engines I do not have here I would need your motor
Dennis Leonhardi
« Reply #2 on: April 29, 2010, 01:25:49 PM »
Randy, I can send you a Thunder Tiger .15 - what would your prices be for tongue muffler, venturi, and needle assembly, and what would you estimate turn-around time to be?  Thanks!
Dennis
« Reply #3 on: April 30, 2010, 02:08:33 PM »
Dennis
Hi Dennis
I check the TT15  and Magnum I have here, I do not have any tongue mufflers or NVAs to fit them
Offline dennis lipsett
« Reply #4 on: May 12, 2010, 10:36:41 AM »
Not to hijack the thread The OS 15 FP Venturi is still available part# LXCW98 at $6.29
The OS15NVA is also still available part# LXCR47 at $13.49
I had Tongue mufflers made by Scott Reese., however that was a few years ago. That said I'd really like to have a steady supply of parts for these 15 engines. I'd certainly be appreciative of any effort on Randys part to supply them.
