  • July 02, 2025, 04:14:52 PM
Author Topic: Landing gear for Vector 40 kit  (Read 4781 times)
Online Paul Allen
« on: December 29, 2009, 03:03:18 AM »
        Do you have alloy landing gear to fit the Vector 40 kit,with more ground
clearance then the one supplied in the kit.
Paul Allen
Australia
Re: Landing gear for Vector 40 kit
« Reply #1 on: December 29, 2009, 08:55:13 AM »
Paul Allen
Australia
Hi Paul
No I only have CF gear that is larger, I have 40 and 60 size CF gear  and  40 sized dural gears
You can use the 60 gear and it will work just fine and raise the ground clearance for you, you can also locate the axle hole in the 40 gear lower and use thin 2.25 or 2.5 inch wheels, this works well too
« Last Edit: December 29, 2009, 06:33:20 PM by RandySmith »
Offline John Witt
« Reply #2 on: December 29, 2009, 04:53:02 PM »
I made this extension for my E-Vector. I fly from a short cut grass field and it works fine. Made from aluminum strip the same width and thickness as the end of the stock gear. It's bolted on through the wheel pants hole and the original axle hole with two 4-40 screws. It doesn't even look too storky.
I love my Vector!
John W
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Online Paul Allen
« Reply #3 on: December 30, 2009, 01:42:34 AM »
OK, thanks guy's.
