Vendors Corner => Aero Products => Topic started by: RandySmith on August 21, 2020, 04:48:49 PM
Title: 35 , 40 46 LA and FP cnc aluminum back plates in stock now
Post by: RandySmith on August 21, 2020, 04:48:49 PM
35 , 40  46 LA  and FP   cnc  aluminum  back plates in stock now,  They are  14.99 each plus  s&h
Title: Re: 35 , 40 46 LA and FP cnc aluminum back plates in stock now
Post by: Joe Ed Pederson on August 21, 2020, 05:30:22 PM
Randy,
Does your email address: randyaero@msn.com still work?  I sent an email to that address on Monday (17 August) in an attempt to order a few things and haven't heard back.
What's the best way to place an order?
Joe Ed Pederson
Cuba, MO
Post by: 944_Jim on August 21, 2020, 07:32:03 PM
Mr. Randy,
I contacted you last winter regarding aluminum backplates for the LA .15. Any chance you'll be making a run of these? I would like two.
Thanks!
Post by: Robert Whitley on August 21, 2020, 07:54:10 PM
Do the .46 backplates also fit .46 FX and AX engines?
Post by: RandySmith on August 22, 2020, 03:31:52 PM
Randy,
Joe Ed Pederson
Cuba, MO
Hi  Joe  yes  the  email  is  correct,  I had  surgery on the morning of the  18th, and  will be  back at work  Monday,  I get about  100 emails a day  so I am behind, I was unable to  read anything  for a couple  days, I will  send  an answer to you  email  now
Regards
Post by: RandySmith on August 22, 2020, 03:37:42 PM
No they  fit the LA  series  not the  larger  FX
Post by: RandySmith on August 22, 2020, 03:38:23 PM
Mr. Randy,
Thanks!
Hi Jim   sorry  I do not  have  those
Regards
Post by: Robert Whitley on August 22, 2020, 08:04:01 PM
Thanks for the info Randy. Also for the ST.56 you sent me via Paul Gibeault.
Post by: RandySmith on January 22, 2021, 05:04:49 PM
A ne w batch  of CNC  LA  FP  backplates  are  now in stock
Post by: Steve Dwyer on August 15, 2022, 07:09:03 AM
Randy,
I sent you an email, I need two OS LA aluminum backplates one for the .40 and one for the .46 (same plate) along with a screw set (Allen socket head) including the head bolts and rear case gaskets.
