  • June 17, 2025, 04:57:58 AM
Author Topic: Short kit from plans  (Read 26692 times)
Offline Leester
« on: December 02, 2006, 04:58:36 PM »
Hi Ed: If I sent a set of plans to you for a short kit to be made and it only shows the Root and Tip ribs is this a problem ?  If not, does it cost alot more than one that all the ribs are the same or shown on the plans.  Thanks
Leester
ama 830538
Offline Action Ed
    • Lazer Works Engraving and Design
Re: Short kit from plans
« Reply #1 on: December 05, 2006, 03:08:28 PM »
Hi Lee,
Yes sir it does. We will have to draw the ribs for you. Normally on this type of activity we charge $25 per hour to create parts. If all the ribs are already there no there is no charge for set up.
Walter Hicks
« Reply #2 on: April 02, 2007, 04:08:08 PM »
Hi ,
  Would it be pissuible for me to send you Contest wood to cut  or do you use contest wood for short kits?
Walter Hicks ?
Offline Action Ed
« Reply #3 on: April 06, 2007, 03:36:59 PM »
Hi Walter!
If you want contest grade wood you're going to have to send it to us.
We use premium wood from Balsa USA. I apologize but I am unable to hand pick wood and Balsa USA does not offer contest grade wood.
Eddie  H^^
Offline Leo Mehl
« Reply #4 on: November 07, 2007, 10:08:11 PM »
Hi Walter!
Eddie  H^^
I can remember the 50's and 60's and the terible wood that was used in kits. These days that just doesnt happen. I have built several kits from wood that was not contest grade and the kits these days use very good wood. To heck with the old days.
Offline Leo Mehl
« Reply #5 on: December 25, 2007, 11:18:25 PM »
I had short kit lazer cut from my plans and everything fit perfect. I think you cannot do any better than this The cost was reasonable and the wood was very good quality. Thank you Ed for doing my Arctic Fox for me. The tabs that you did on the ribs was perfect!
