  • July 07, 2025, 11:09:03 AM
Author Topic: XP-56  (Read 2554 times)
Online john vlna
XP-56
« on: February 06, 2015, 12:44:56 PM »
The XP-56 was one of three unusual WWII prototypes, the other being the XP-54 and 55.
I have built a XP-54 and it is a good flier. The XP-56 uses a 1/4A  (.020) size motor as far as power comparisons go, but has a 7x3.5 prop, an unlikely choice for a .02 PeeWee.
Battery is a 2 cell. Span is 20 inches. Hopfully it will fly this weekend
Re: XP-56
« Reply #1 on: February 06, 2015, 01:32:08 PM »
Looked great until I seen the bottom side.   What a nightmare. LL~ LL~
Online CircuitFlyer
    • www.circuitflyer.com
Re: XP-56
« Reply #2 on: February 06, 2015, 08:03:54 PM »
That is a very interesting bellcrank linkage.  It must have taken a lot of time to work that out.  Great job.  Good luck with the maiden flight.
Paul Emmerson
Offline mike londke
Re: XP-56
« Reply #3 on: February 06, 2015, 09:22:33 PM »
Neat!
Online john vlna
Re: XP-56
« Reply #4 on: February 08, 2015, 10:27:46 AM »
Well even with the messy bottom pointed out by Doc, it flies very well. Not a stunter but nice touch and goes. Balance was right on. I need to adjust for more up than down. The small elevators out of the prop blast are ineffective until the take off roll is at high speed. Also it needs a bit of down thrust(I think) since it flies a bit nose high. All in all I a very happy. A bigger one would make an interesting fun or profile scale model.
Re: XP-56
« Reply #5 on: February 08, 2015, 02:52:36 PM »
Isn't that the one the Northrop engineers reffered to as the "ascender" as a play on the engines location?
Hi Chief,
The XP-55 was the "Ascender", very similar looks.
BIG Bear
RNMM/AMM
Online john vlna
Re: XP-56
« Reply #6 on: February 08, 2015, 06:50:13 PM »
The Northrup XP-56 was called the Black Bullet.
Re: XP-56
« Reply #7 on: February 08, 2015, 07:11:19 PM »
 The "beauty" of electric. :P
 Really neat airplane though. I'd love to see a bigger version with an IC .15 or .25. y1
