  • August 01, 2025, 08:19:41 PM
Author Topic: Will TD's run either direction?  (Read 1987 times)
Offline Tim Stagg
« on: February 24, 2019, 02:20:48 PM »
I know they will start either direction, but do they perform equally either way?
Tim Stagg
Re: Will TD's run either direction?
« Reply #1 on: February 24, 2019, 02:31:25 PM »
They are a shaft induction system and should only run great counter clockwise.   Just like standard shaft induction engine you need to retime the shaft to get them to run clockwise.   That is if you are standing in front of the engine.   Reed valve engines will run either direction. D>K
Offline bob whitney
« Reply #2 on: February 24, 2019, 03:09:17 PM »
they made a left hand crank for the TD for speed. then u would need a L H prop
rad racer
Offline Tim Stagg
« Reply #3 on: February 24, 2019, 04:24:09 PM »
Thanks guys that is what I needed to know.
Counterclockwise it is  8)
Tim Stagg
Offline Fredvon4
  • Central Texas
« Reply #4 on: February 25, 2019, 10:14:57 AM »
WHY
LH cranks frequently come upon the e-bay... I had several...now down to one I am keeping
I never saw any Medallion LF cranks all I ever found were the square intake TeeDee versions
Not sure if Paul Gibeault still has any in his junk barrel or Mike Hazel
Fred von Gortler IV
Offline Larry Renger
« Reply #5 on: February 26, 2019, 09:35:03 AM »
 I actually have one left hand crankshaft I think they were very unusual.  H^^
« Reply #6 on: February 26, 2019, 10:02:36 AM »
The typical high-performance shaft induction system will run either way because the induction opens early, to give the crankcase time to fill when the engine is going fast.  But they don't run at all well in reverse.
One of the compromises that "sport" engines like the LA series makes is to make the induction open later.  This makes it much easier to hand-start the engine and have it go forward, but it limits the top speed.
You could make a rotary induction engine run equally well in forward or reverse, by placing the induction hole (or disk or drum) so that it opens equally on both sides of top dead center -- but if you did that, you may as well use piston timing.
