Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
August 01, 2025, 05:05:05 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
1/2 A building.
(Moderator:
Joey Mathison 9806
blank
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: blank (Read 2523 times)
Motorman
Trade Count:
0
Admiral
blank
on:
September 14, 2021, 08:57:22 PM »
blank
Last Edit: September 21, 2021, 06:37:04 PM by Motorman
Logged
944_Jim
25 supporter
Trade Count:
0
Admiral
Re: White Lightening
Reply #1 on:
September 14, 2021, 09:52:03 PM »
MM,
Is that a profile fuselage, slab wing plane with 28" wingspan?
Logged
944_Jim
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
September 15, 2021, 03:53:10 PM »
That is too funny! ISTR every time I've seen the model on websites, it has always been white. I reluctantly posted the image after careful review if your blue one. Full size plans are out there. I'll see if I can find them quickly.
Logged
944_Jim
25 supporter
Trade Count:
0
Admiral
Reply #3 on:
September 15, 2021, 03:57:18 PM »
https://www.hippocketaeronautics.com/cl_sp_white_lightning.htm
PDF is there.
Logged
kenneth cook
Trade Count:
0
Admiral
Reply #4 on:
September 15, 2021, 05:25:39 PM »
I built one a few years ago. The plans called for a Cox TD or a Norvel. Well, neither balanced the model. Just as a idea, the weight of a TD .09 is approximately what 2 TD .049's weigh. It took that much weight. I asked Bruce about this and he said their example worked. I liked the design, the simplicity but the wing flexes which compromises maneuverability and this also happens on smaller sheet wingers like the Skyray. I removed the wing and had Phil Cartier cut me a extended version of his Lil Hacker foam wing. I moved the wing back and it flew a lot better.
https://www.hippocketaeronautics.com/cl_sp_white_light_build.htm
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
1/2 A building.
(Moderator:
Joey Mathison 9806
blank
