  • July 31, 2025, 01:57:46 PM
Author Topic: Pat King micro Ringmaster twin  (Read 13876 times)
Offline Dave Nyce
  • Flying
    • Revolution Sensor Company
« on: December 12, 2024, 08:25:08 AM »
Finished building a micro Ringmaster twin kit by Pat King. It has two Cox Tee Dee .010 engines. Very nice kit.
I added a wingtip weight box. Put some lead inside the nose wheel to balance fore/aft.
I planked one extra bay in the wing to make covering easier.
Pat King has lots of control line kits and plans available.
Dave Nyce   New Bern, NC
AMA: L356
Re: Pat King micro Ringmaster twin
« Reply #1 on: December 13, 2024, 01:54:38 AM »
Lookat all da jewelery on the front of that thang!
Nice job!
Offline 944_Jim
« Reply #2 on: December 14, 2024, 08:43:49 AM »
I'm a sucker for twins. This one is just too cute!
Great job. Please post links to flight vids.
« Reply #3 on: December 15, 2024, 12:15:35 AM »
As Air Miniseries would have said (before his reformation as Scientification):  "now we can see why you inventicated that mini'lectic starter thingymabobber--A Twinney!"
Offline Mike Hazel
« Reply #4 on: December 15, 2024, 09:26:46 AM »
I have the little Pat King single engine micro Ringmaster.  As much "fun" as it is to start one .010, hard to imagine the "joy" of getting two of them going.
Offline Dave Nyce
  • Flying
« Reply #5 on: January 01, 2025, 03:53:52 PM »
I don't really have any trouble starting mine. I have six TeeDee .010 engines.  I made a small electric starter for them. Also works on my .020 engines.
AMA: L356
Offline 944_Jim
« Reply #6 on: January 01, 2025, 04:27:06 PM »
Mr. Dave,
I'd like to see the starter. What did you use for the starter cone and holder?
Offline Dave Nyce
  • Flying
« Reply #7 on: January 02, 2025, 03:11:25 PM »
I bought a motor, a LiPo battery, and a high current micro switch on Amazon. Made depressions into a piece of wood for the motor and battery. Drilled into a piece of aluminum rod for the motor shaft at one end and a piece of rubber tube at the other end.
« Last Edit: January 02, 2025, 05:26:30 PM by Dave Nyce »
AMA: L356
Offline Shorts,David
« Reply #8 on: January 06, 2025, 05:10:50 PM »
And what fuel/duration can you get with them? What length and line size? Lap time?
Offline Dave Nyce
  • Flying
« Reply #9 on: January 06, 2025, 09:13:54 PM »
I use sig champion 25 fuel of which I still have a few quarts. 10 pound test yellow braided line, 15 to 20 ft long, depending on the model. But I haven't flown the twin yet. Maybe a little longer line for the twin. With .010 integral tank, runs about 1 minute. But I use external tank on most, for run time 2 to 3 minutes.
AMA: L356
« Reply #10 on: January 15, 2025, 03:53:45 PM »
Thanks Dave,
I'm just wondering if someone can get an official pattern flight with 2 010 engines.  I just got a pair and I'm wondering if it'll be worth the effort.
Offline Larry Renger
« Reply #11 on: January 18, 2025, 07:29:35 AM »
I had a 1/2A Snapper with a .010 and it could do a complete pattern. I have witnesses who saw it. 🤠
