  • July 08, 2025, 03:14:15 AM
Author Topic: wasp 061  (Read 1107 times)
Offline Bootlegger
wasp 061
« on: December 25, 2012, 09:53:11 AM »
  Does the wasp .061 have head gaskets/shims? I just pulled the head/globutton off one and didn't see a gasket.
  Also if is supposed to have one, what will fit? Any thing from cox engines?
  Thanks a lot, Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Andrew Tinsley
Re: wasp 061
« Reply #1 on: December 25, 2012, 12:42:47 PM »
Hello Gil,
Anythining that fits a Cox will fit a Wasp. Same head threads, so all is easy. You are better off ditching the existing glow button / head once the plug burns out. The plugs are expensive and not all that readily available. Use a Galbreath Head and Nelson plug or buy a Merlin head and use their glow buttons. With either of these heads, you will probably want to decompress a little using Cox head shims.
Happy Christmas,
Andrew.
BMFA Number 64862
