Building Tips and technical articles. => 1/2 A building. => Topic started by: Jared Hays on January 20, 2014, 08:01:45 AM
Built a SIG skyray for my girlfriends son and would just assume make it electric. Also have a Cox Hyper Viper that is underpowered even with a Killer Bee .049 installed.
What motor, esc, battery's, and timers would I need to do this. Not up to speed on motor size and performance of the electric stuff. Where can I get timers for these?
Go to the electric section or PM Dennis Adimisin.
Eric Rule at rsmdistribution.com can sell you a complete, ready to install setup.
Go over to the "Getting all amp'd up" forum and look in the "List Your Setup" thread -- there are some 1/2-A sized planes in there. Keep in mind that for a trainer you don't need as much power, and may not want it.
Do a search on "ET-1". You'll find a Coreplast trainer designed by Larry Reniger. The recommended power system for that should power the Skyray just fine.
For the Viper, weigh it, then let us know.
I built a pair of ET-1's for my nephews for Christmas in 2012. I took Larry's recommendation to use a radio for throttle. It works great, for a beginner it lets you cut throttle when they're getting bored, dizzy, or into trouble, and for a plane that can only go around in circles it adds a dimension of fun. All the electronic stuff for a plane was about $70 from Hobby King, including extra batteries and a charger. The more you already have, the lower the price.
I'd get cheap motors -- he'll be using them for landing gear a lot, so you'll be replacing them.
thanks guys I'll try to weigh the Viper when I get home.
I fly my Skyray with a Turnigy 2730-1700Kv , 500 mah 3s , Brodak timer and 12 amp esc, Every bit as good as a COX will do all stunts that a Skyray can do.
My cox Hyper Viper weighs 12oz with a .049 Killer Bee motor in it.
Holy crap, don't really want to put a $170 setup in a $40 plane lol
If you want to play, you have to pay. But, once you get past the initial cost look at the possibilities. I remember my first .35 size engine and thought that was way too much money.
You can get it way cheaper at Hobby King. It'll be cheaper in all senses, not just "less money", but for a trainer that's going to be crashed anyway, why not?
Yea I have a bunch of electric R/C stuff anyway so I know the savings potential from Hobbyking/CopyKing so I'll just go that route. I just don't understand all the #'s you see when looking at electric motors...Wish Hobbyking would list them like the $170 setup website. "This electric motor is replacement for .61-.76 glow motor" So thats what I need to know. What motor's and such. The skyray setup above I will pry just copy for my skyray since he said its comparable to cox .049 but my Hyper Viper could use .061 power. So need a turnigy motor for it that would be a little more than the skyray one.
I can see how it would get confusing. A good part of my living is designing motor drive circuits as well as control systems that use them, so sizing motors and electronics is a practiced art here. Even though I know it in and out, it's still a tedious job to find all the right bits and pieces, particularly when you have to add a bit of distrust in the specifications into the mix.
