Building Tips and technical articles. => 1/2 A building. => Topic started by: Vincent Corwell on April 08, 2009, 01:31:21 AM
Are venturi + needle assemblies available for the AP 061 ?
I have 2 of these, and they are great , except for very fiddly
needle setting with the carb wired open, wonder would they
be more stable with a conventional venturi / needle setup ?
Vincent H^^
I was at Hobby People the other day to order a new crankcase for a Wasp, and Mark, the manager said that they used to import a CL version of the engine! Anybody seen one?
Also, I have been asked by Eric Rule (RSM Distribution) to design a venturi for the engine, and I will.
Way to go Larry,, i am anxious to see if you can fit a spraybar thru that small hole in the crankcase or if you have to put it above in the venturi itself.. Hurry up!! H^^
Does that mean that conversion parts could be imported
direct from source ?
Vincent
"Does that mean that conversion parts could be imported
direct from source ?"
I would think so. I am going to investigate that too.
Great !!
when can I get 2 venturis with needle assemblies ?
First off, after a bit of thinking and measuring and thinking some more I was still stumped on how to make a nice control line venturi/needle valve for the AP061. The two small holes on the crankcase where the two small retaining screws for the throttle go are too small to fit a needle valve and the there is not enough meat to comfortably thread so as to take a couple of grub screws to hold something in place.
So, a bit more thinking, fussing, measuring and some more thinking the answer popped into my head - I found I could mount a Cox 049/051 Tee Dee venturi/needle valve assemble to the AP061 and all I needed to do was make a small adapter and glue it into the AP061 crankcase.
Easier said than done in fact. This small adapter needed to be threaded 1/4-32 so that the Cox venturi would screw into it like it does on the Tee Dee's and it needed to fit the small diameter of the AP061 crankcase as well. To put it into perspective, the outside diameter of the 1/4-32 thread is 1/4" or .250 (in reality a wee bit less) and the outside diameter of this small adapter needs to be .276". Not a lot of room.
Drilling and tapping a 3/8" piece of 6061-t6 aluminum was easy as was turning - carefully - down to .276" diameter. Parting the piece off was another story. I would just get started parting the piece off and it would shear off on one of the internal threads leaving a piece as long as I needed plus the length of the parting tool. I managed to clean it up however, just required 10 minutes of fussing to get it done. I tried cutting one off using a Zona razor saw but once I got the cut started the blade was dragged off course by the internal thread.
All in all, not a difficult machining job just one that was fussy. The end result is a little adapter that I will glue or rather retain in the AP061 crankcase with Loctite 609 retainer. 620 or 648 would work too but I happen to have 609. These types of retainers are not the same as thread lockers. They are made to cure in the absence of air and are used to fix parts together that have close fitting tolerances such as a gear or pulley on a shaft.
Photo one shows the AP061 with the Cox Tee Dee venturi assembly fitted, photo two shows the parts of the Cox venturi assembly and the adapter is the little aluminum piece in the foreground.
Dimensions for those interested are .276" diameter by .165" long.
An even easier way of making a servicable control line venturi for the AP061 is to use the throttle that it comes with. No, I am not talking about wiring the throttle wide open and leaving it at that but the end result is pretty much the same.
It seems the steel barrel screws onto the brass fuel nipple/orifice and is what retains the barrel in the carb. Basically what you do is
1) remove the needle valve
2) remove the clickers and throttle arm by removing it's retaing nut - use a 5mm nut driver
3) unscrew the steel throttle body
4) degrease and clean the carb body and throttle barrel
5) using Loctite 609 or similar retaining product (not threadlocker) on the inside surface of the throttle body and externally on the throttle barrel - screw the barrel back onto the brass fuel nipple/orifice. Be careful not to get any retaining fluid on the brass orifice or you will never get the brass fuel nipple out again (unless that is of course if you want)
6) reassemble and replace the throttle arm with a washer and you now have a serviceable control line venturi for the cost of a bit of time and some Loctite retaining compound.
Photo three shows the venturi mounted on the engine and photo four shows the parts of the throttle
cheers, Graham in Ottawa Canada
Good show! and great photos. How does the Tee Dee venturi run? Are you using it to fly aerobatics?
Thanks. I am more a sport flyer than anything else. One of these engines will be going a White Lightning all sheet design, details here: http://www.hippocketaeronautics.com/cl_sp_white_lightening.htm
I measure the Tee Dee venturi at .116" diameter and the AP 061 carb at .120. the air flow through the Tee Dee venturi is cleaner with less sharp bumps than the AP061 carb and a more "venturi" like profile rather than just a straight sided hole.
I have only run the Tee dee mod a couple of times on the bench and it is runs pretty much the same as with the AP061 carb. With a Cox gray 5x4 prop and AP061 carb I was taching around 19.5K. I didn't tach it with the Tee Dee mod. The Tee Dee needle has a finer thread and has a bit more feel. My preference is for the Tee Dee version.
Of course, if you have one of the KK needle valve assemblies that would work too. Hank Nystrom of Texas Timers still sells a KK like needle valve assemble, details here:
http://www.texastimers.com/accessories/needle_valves.htm
cheers, Graham
Graham,
Great idea, but Tee Dee parts are rather expensive, and are getting harder to find.
Looks like the carb barrel fixing would be more practical.
There are only a few conventional half A size needle valve and spray bar assemblies in production today (Brodak) but making a venturi tube that fits one of those might be the way to go. Unfortunately, increased demand would probably drive the price and availability closer to Cox prices in short order.
Would you consider selling the TD venturi adaptors?
Great work Graham, thanks for the report!! Did the carb barrel fix last summer, runs fine but i couldn't get the hole lined up in the exact center of the venturi , may try to make a washer to shim it out a little or drill the hole in the barrel out a little but it does run okay. Had thought about the tee dee venturi and even trying to drill out the holes in the crankcase to fit a Driskill spraybar but both seemed too "iffy" . I now run one AP with the throttle wired and one with the barrel fix, both run fine, but both have had the venturi screws in the crankcase come loose at least once!! Ray
On your adapter. It might be easier to part off if you leave a flange on one end, .010-.020 thick, with the OD the same as the flats on the engine carb boss. The air seal to the cox parts wouldn't suffer from a little extra contact surface anyhow.
I several cases with the venturi screws coming out on the AP's to the point I finally just took them out, mixed up some JB Weld, and cemented the venturi in place. No issues to date, plus if you go in inverted, it doesn't crack the casing, the Venturi just releases from the body. Recement it in place with some more JB and your back to flying in a couple hours.
Good idea Don, I will have to give it a try. The problem I was having was that once the parting tool reached one of the internal threads the metal would tear along the thread. I had a thought to make up and try a much thinner parting tool perhaps 1/16" (or smaller) and make it nice and sharp. I knew it would be tough job to part these pieces off and I was turning spindle by hand to do it just so I could watch and keep it under control.
cheers, Graham
That is one way to skin the proverbial cat. I was chatting with another flyer just recently about this very subject and he mentioned that they (the group he flies with) was making venturis out of delrin and gluing them in with JB Weld. I would have thought that delrin would not bond well with JB weld - I have never tried it so I am just guessing. Their venturis are just turned to size with a conventional needle valve crossways through the tube. I had considered that too but I had a Tee dee assembly sitting around and thought it a better way to do it. I guess in the end, whatever works and is reliable is just as good as any other - unless you are looking for that last 1%.
Got me thinking though. I often see venturis made from delrin or similar rather than aluminum. Any good reason why? Cost, machinability, or something I hadn't considered?
cheers, Graham
Graham,
Bill,
Yes indeed, Cox parts are getting harder to find and more expensive. I just happened to have an assembly lying around without a proper home and thought it would work out well and so far it has.
I had considered just turning a venturi "tube" and mounting a needle assembly crossways as is commonly seen and I may just try that as well. It would certainly be a more conventional approach and not limited to trying to find Tee Dee assemblies.
Would I consider selling them? I could be convinced to making a few more. If you would like to give one a try I can send a couple your way.
cheers, Graham
I am surprised no one has mentioned that my AP061's don't have the typical AP061 spinner nut. They both have Norvel cranks and Cox red anodized spinners on them.
cheers, Graham
Graham,
I also have a spare TD needle and venturi, and would be interested in the adaptor, or any venturi tubes you make.
Anyone know if the Brodak needle and spray bar can be adapted? They are certainly cheap enough, but I haven't seen one.
I did notice your hex head prop screw (and glow head adaptor), but thought I might have missed something in my instructions about removing a prop stud?
Don't know why Delrin is popular, but considered it for my OS FP engines needing a c/l venturi. My thinking is that the Delrin would flex a little, and perhaps enough to save the crankcase in a crash.
I think the delrin is used to try to insulate the needle valve assy from engine crankcase heat. As far as machining, I'd rather make something from 2011 alum bar stock than any plastic, the plastic moves around too much! I have found 2011 to be the easiest machining alum around, I get mine from McMaster-Carr.
Don,
I don't know that I have ever used 2011 aluminium before. I prefer 7075 as I find it turns nicer than 2024 or 6061, 2024 is my second choice but 6061 will do. I don't like to keep a bunch of different stuff around so I tend to buy the 7075 when I need something and buy enough that there is enough around for other projects. I am lucky, I have a Metal Supermarket store handy. Very convenient even if their prices are sometimes a bit more than others; and of course I am constantly on prowl for scraps and cast offs. I just found a big chuck of cast iron on the side of the road the other day maybe 3" wide, a foot long and almost 1-1/2" thick. Don't know what I will do it but in the mean time it makes a dandy weight for holding things while they dry.
cheers, Graham
I've seen a picture of the c/l version of the AP .09 . Soon as I get to town again I'm sending the carb off the .09 and a enya .09 needle valve to Lee's machine to make me a venture for the .09 . I'll let you all know how it works.
I just stumbled on the 2011 alum from McMaster-Carr when looking for hex bar stock to make prop nuts and venturis. I agree that 2024 or 7075 will machine very nicely but it is rather hard to find. The best part for me, McM-C is real rapid delivery, usually next day, and I don't even have to leave home! They stock a large variety of sizes.
Here is a picture of the control line version of the AP .09
another photo
Grahm Collins sent me a couple of his adapters. I installed one and flew it today. WOW! I think I both gained rpm and got a steadier run. The plane turned 3.8 second laps on 45 foot lines running 15/24/2 fuel. Rock solid through maneuvers. I am one happy camper.
This was using a stock Tee Dee needle assembly. I will try the Texas Timers fine thread assembly next.
In addition, I started the machining of a custom venturi that uses the smallest of Eric Rule's needle/spraybar assemblies. What with grandkids and Mother's day, it will probably not be finished until next week.
Got as far as checking my adapters in an AP case, and they are a perfect fit!
Did you use the same Locktite adhesive Graham suggested?
So Larry, where are we in regard to having a venturi/nva available for these little beasties?
Well, I tried to turn a new venturi per my drawings out of some plastic I THOUGHT was Delrin, but it must be HDPE, as machining it was a nightmare. Couple of hours wasted. I'll do one in Aluminum!
Other than that, it is clear that the engine can be mightily improved by a new, better carb system. I suspect the needle in the stock carb vibrates and causes erratic settings. I found the other day that turning the needle in made the mix RICHER at first, then too lean. Wierd. The Cox conversion so far seems totally predictable. If TD parts were a dime a dozen on every street corner, I would recommend that solution in a heartbeat. However, I like to support technology that is available to everyone, thus designing a venturi for RSM to use with their needle/spraybar assemblies. But first, I have to make a working sample, and my lathe is making a funny noise all of a sudden. :X HB~> :'( ???
Thanks for the update. I'll want one when you get it ready.
What exactly are these adapters your talking about Bill Adair ?
Larry,
"Well, I tried to turn a new venturi per my drawings out of some plastic I THOUGHT was Delrin, but it must be HDPE, as machining it was a nightmare. Couple of hours wasted. I'll do one in Aluminum!"
Just call Henry Nelson. He makes the cox venturi in quite a few sizes for his rear intake team race engines. Also can't beat the price and elimination of hassle.
Jim,
They are a threaded sleeve that is glued into the AP Wasp carb mount hole. The sleeve fits a Cox Tee Dee Venturi, so you need a TD venturi, needle valve body, and of course a needle valve, to make it work.
Unfortunately, those Cox parts are getting expensive.
I purchased one of the Ap's a few months ago. I'm currently building the White Lightning and initially had a TD set for power. Lately, I've been having fuel feed issues with the TD's. I don't seem to have the same issues with the Norvel's and Stel's engines I'm running. It seems that the plane is maneuvering so quickly its running away from the fuel. Looking at my Ap tonight I was noticing the difficulties as described above trying to get a venturi needle set up. I also figured in the event I was to use the stock set up, would opening the venturi hole and also the carb barrel give a bit more performance? Would this enhance performance or comprimise fuel draw? It always seems to me that carbs in general never give the same run or rpm's that the standard venturi and needle give. I was able to build this profile with the ability to switch engines. Larry Renger stated some time ago that even though the bolt pattern is typical the case length is not. I was able to meet in the middle before drilling my holes. I now have a plane with little effort I can switch engines. I feel this Ap is going to be the winner here. I'm quite fond of the price and its availability. I can't wait till my plane is finished. I've had it on the back burner for over a year and made some real headway the last few days. Ken
I was commenting that the Tee Dee Adapter that Grahm Collins sent works gangbusters in my first flights. The venturi I am designing is a single unit that uses RSM's 001 needle/spraybar assembly. The two systems are totally different. I hope to meet the level of performance of Grahm's system with a more economical and available system. In the meantime, if Grahm will sell you an adapter and you have the venturi and spraybar TD parts, go for it!
Good day all,
Thanks for the update Larry and Bill. Glad to hear you are pleased with your results.
I have been doing some more bench running with my AP061 and Tee Dee set up - I haven't had the chance to get out flying much so it is the next best thing.
The engine I modified is still performing well on the bench. Turning a Graupner nylon club of a propeller of size 6x3 it runs pretty steady at 18.5 to 19k. I still have a fuel tank problem and will have to solder up a new one. I have been trying the film container tanks a try and for some reason they are leaking around the snap on cap and I haven't figured out why - makes quite a mess
After a half dozen runs I noticed that one of the head hold down bolts seemed to be missing. After I stripped the engine down it turns out I had somehow managed to twist the head off one of the bolts and hadn't noticed - busted clean off and flush with the crankcase. I use a torque driver just so that I don't overtighten these tiny bolts and these where the original bolts so there must have been one that was a bit "below standard" to have broken off so easily.
I wasn't sure how I was going to get it out. I tried an old trick of using a warmed solution of alum soaking overnight. The alum will encourage the oxidation of steel/iron and does nothing to non-ferrous metals. Funny thing was that when I checked in the morning the whole crankcase had turned an interesting colour of grey not unlike oxidized magnesium. The soaking loosened up the broken off bolt enough I was able to turn it out through the bottom after much fussing and after a good scrubbing under running water the crankcase looks non the worse for wear except for the tarnished colour. In my notes I had previously noted the weight of this crankcase as 14.6 grams and now it is 14.4 grams - clearly it has lost some of it's metal due no doubt to some sort of oxidation but alum is not supposed to cause aluminum to oxidize! The insert in the venturi for the Tee Dee parts was just a shiny as it was when I put it in (it is made from 6061 aluminum). So the question is - what is the crankcase cast from ? Aluminum no doubt but what else is in it's make up? Silicon? ? ? Anyone care to take stab at an explanation?
And further to the broken bolt I discovered the piston/cylinder has a very nice scratch/gouge in it! Possibly from a blown glow plug. Oh, well it was still running well so I will put this one back together and use it as is. I guess it's time to get another new one!
As to availability and cost of Cox parts - yes these parts are getting harder to find and on the pricey side. However, Bernie AKA Xenalook on eBay is now listing Tee Dee needle valve parts but not the venturi part. I have been meaning to contact him and see if he will be reintroducing these parts as well. He has stated that he intends to start manufacturing some other Cox parts but is pretty quiet on exactly which ones.
http://stores.shop.ebay.com/XENALOOK Maybe if enough people pester Bernie?
Select Hobbies lists some Tee Dee parts http://www.selecthobbies.com/enginepartsdata.htm but are a bit pricey.
I am sure Larry will come up with something quite suitable but in the mean time, if someone would like to try the Tee Dee mod I can make up some more of the little sleeves/adapter. email or PM please.
cheers, Graham
Graham... email send.
All film canisters are not created equal--get a sackful and sort through them. You'll find some will have very tight fitting caps; use those for straight tanks. The loose ones are still good for balloon tanks or pressure bladders.
You can get them by the carload at any camera store, or anywhere that still develops old-fashioned film!
I try but all the local camera stores see so little film these days that they rarely have more than a couple on hand when I ask. Unless someone asks for them they go in the daily recycle bins. APS containers are even harder to come by.
cheers, Graham
Maybe you could ask them to save 'em for you rather than recycle. But camera stores aren't the only source--the last batch I got was from a local drug store that does film developing. They seemed glad to have me take them off their hands.
Will silicon glue work for sealing the lids to the canister? Been wanting to try those tanks. DOC Holliday
Goop adhesive is the stuff to use. It isn't perfect, but takes about a year to break down from fuel exposure. Silicone Seal is nowhere nearly as good in my experience.
I ran and flew my new venturi system. It works! The engine is still breaking in, so I am not blown away by the performance, but I got a good, steady run through maneuvers. The Tee Dee venturi engine is coming on stronger all the while. I was turning 3.6 second laps on 45' lines with an APC 6x2 prop. Burns a lot more fuel than the stock engine, but the run is solid everywhere and the needling is smooth and controllable. Good progress on all fronts!
I will have to re-measure, but I am pretty sure the Tee Dee Venturi has more passage area than the Wasp carb, and the flow is cleaner, thus more power. Happily, the fuel draw is excellent despite the larger area.
Larry,
Thanks for the report on your modified AP Wasp engine. Good news indeed. H^^
I'm going to mount my Wasp on the bench, and do some break in runs on the stock engine. When it's run in a bit, I'll do the TD venturi installation, and get a comparison.
Great! Yes, I need to do the same kind of testing with my venturi. I have corrected the drawings to eliminate errors and missed dimensions on the first version, and will turn a new one very soon. I will put that on a new, but broken-in engine after rpm tests for a baseline. I am designing mine around Eric Rule's (RSM Distribution) Super Tigre clone needle/spraybar assembly. Adjustable needle tension, and rock solid structure, what's not to like? I find the adjustments very controllable with this needle setup. All I really need to determine is the bore size for optimum performance.
Larry,
Looking forward to your venturi tests!
I've looked at Eric's web site, but only see the larger Super Tiger needle valves. Which one are you using?
Ran one of my new AP Wasps on the bench today.
None of the shops around here stock the all Castor fuel the AP instructions recommend, so I had to compromise. Used a pint of my thirteen year old Dukes fuel, with added Castor to bring it up from the original twenty percent pure Castor, to twentyeight percent Castor. Added enough Norvel 35 percent nitro fuel, to bring the total nitro closer to fifteen percent. I calculate the blend to be twentyfour percent pure Castor, plus a little synthetic from the Norvel fuel.
The first run (3/4 oz tank), using a 5.7 X 3 APC prop, with the carb wired wide open, gave me a steady 15,300 rpm. The second run showed 16,400 rpm! Both runs were just off peak rpm, so the the engine leaned out normally at the end of both tanks.
Had to use my starter for all starts, because the piston to cylinder fit is very tight. Hand flipping never got it past the first compression stroke.
One thing I noticed while adjusting the needle valve, is that it's very sensitive to touch, and pushing down very lightly on the needle seemed to richen the mixture, and dropped the rpm a noticeable amount. I suspect the R/C carb tolerances are a bit loose, but a fixed venturi should cure that.
Sounds like you may have a little air leak. Have you tried any Teflon tape on the needle? DOC Holliday
Hi Doc,
The AP carb probably has air leak issues as well, but in this case I think it's loose threads on the needle valve/carb rotor. The engine appeared to richen up and not lean out when pressing on the needle valve knob. I'm going to use a short length of fuel tubing to seal the needle for the next runs.
The whole reason I got into designing a new venturi is the uncertainty of any setting on the stock needle in the AP Wasp carb.
If it is an air leak past the needle, Plumbers teflon sealing putty on the threads should fix that! Hmm, now that I have thought of it, I shall have to try it!
I found that I mis-calculated the drill size needed for my venturi design, and will have to turn a new one. The Tee Dee setup is still going gangbusters, but I can't cram enough fuel into the model to make the pattern - TOO MUCH power, I guess.
Installed a short length of medium fuel tubing under the needle valve, and hope to get some more runs on the bench next week. Easy to see why the needle settings are eratic, as the fit of the needle is very sloppy.
Bill I found this to be the case on mine (3 over time) and have started removing the set screws when I get mine new and use old style JB weld to hold it in. A little on the rim of the carb, then a lot around the outside. Engine runs are much more consistent, plus when the inevitable happens and I go in inverted, the carb just breaks loose instead of cracking the housing like it did when using the screws. (this is for side mounted engines which makes the needle point up)
The carb can be reversed to have the needle point down! You will burn your fingers from the exhaust if you are not using a muffer, though. An old trick is to use a dowel with some rubber tube as a temporary extension/tool to adjust the needle, then pull it off when flying.
Ran my Wasp again yesterday, and it continues to pick up RPM as it breaks in. It's turning over 17K now, with the 5.7 X 3 APC, on my make shift fuel blend.
A short length of medium fuel tubing under the needle valve, cured the touchy needle settings I was seeing before.
It starts by hand flipping now, but is still not easy to get running when cold.
Did you remove the sheet metal spring stop when you added the fuel tubing seal? Photos, perhaps?
I am using the "001" NV assembly for my venturis, but have to turn special washers .0625 thick and .22 diameter as spacers to clear the heads of the retaining screws and center the hole in the spraybar.
I hope to turn out the next version tomorrow. I had failed to subtract the obstruction of the needle and jet from the bore of the carb in my calculations and it was significant! My first versions are WAY oversize, and the engine hates it! I have a spreadsheet where you can plug in the venturi bore and spraybar diameter and get a really accurate passage area output. I can add an equivalent unobstructed bore size column to compare to things like the Tee Dee venturi. Drop me an e-mail if you want a copy.
I suspect that a standard setup of venturi and spraybar will never match the clean flow of the Tee Dee. But it will be more reliable and compact than the stock carb setup.
Hi all
I started this thread and I am waiting patiently
to buy 2 assemblies, I dont see the small needle
assembly on RSMs web site,
Is there a small version
will Eric be offering the complete unit to convert
to control line please?..........cant wait as I have
2 of the AP 061 engines in a stretched Baby
Flite Streak twin, cant get both to run reliably
and I reckon the venture/needle conversion will
solve the problem
thanks to all for the replies, some very good tips there
Photo now included below
Vincent
Neat model!
Development of the venturi for RSM is not complete. I hope to turn a new test article today and test it this weekend. After I am satisfied, I expect it will be several weeks before Eric would have the conversion kits available. For the time being try the fuel hose trick mentioned above, or get some plumber's teflon joint compound and seal the needle thread area.
Stan Tyler just completed a twin Flite Streak for two Tee Dee .049s. His is a scale of the Classic legal design, I don't recall the designer. Joe Bellcrank (John Miller) has the plans. Stan is having trouble keeping the outboard engine running the full flight. I suspect overheating. My contention is that the centripital (or centrifugal, I never could keep them straight) force on the outboard engine is greater, so it leans out more. I think he needs to send the plane off with the outboard engine noticeably richer than the inboard one.
...also to insure the outboard runs out of fuel and quits first!
I built a twin using two McCoy .19s many years ago, a real blast. At least once the inboard engine quit; it continued to fly on the outboard only, but very scarily...line tension was virtually undetectable. Just enough control to keep it out of the ground.
No, I just estimated the length of medium fuel tubing it would take to seal up against the needle detente spring at the carb side, and to ride up onto the taper of the internally threaded needle outer housing, an eighth of an inch or so.
I cut both ends of the fuel tubing square, forced it over the threaded spray bar, and screwed the needle back in. The tubing is small enough to fit under the detente spring without interference, but large enough to let the tapered end of the needle outer housing squeeze into the tubing. Seals at both ends of the fuel tubing, and holds the needle solidly in place, but the needle can still be turned to fine tune the mixture.
Not sure how that will hold under flight loads, but it ran quite steadily on the bench, and just touching the needle no longer changes the mixture.
Hope to have the Wasp broke in soon, so I can get some baseline RPM readings, before the Tee Dee mod.
Well, I am now satisfied with the venturi design and will turn it over to Eric Rule for production. He has a source that looked at the preliminary drawings and says it will be no problem. #^
Larry,
That's good news! H^^
I'll be watching for the release announcement.
Larry , I have to ask, how did your new venturi compare to
the Tee Dee venturi ?
Hey Larry, price? And can we pre-order? And can we see a picture? And...
I'll have to beg for some time on both the above questions. I need to tach the two engines with the same prop and fuel. I expect that Eric hasn't a clue yet on what the carb setup will cost.
I can, at least do some photos. I'll post some later today.
Here it is! ;D
I suggest getting an NVA from Doug Galbreath. They're a lot more compact and made for small engines. And as anything fomr Doug, super high quality.
http://www.the-printer.net/DookCat.html#rossi
Larry,
Very nice! H^^
Did you use the original carb mounting screws?
I finally took my Wasp out and ran it today, 1st time. Typical of these pinched-top engines, the first start was kind of a bear, took a little while, but it got progressively easier to start with each run. Not the equal of a Norvel .061 yet, but maybe after it loosens up a little more. I'd estimate it's putting out about the power of my good Black Widow, maybe a skosh better, not much more than that right now.
But I gotta say, those RC carbs on these things stink. Yes, touching the needle changes the setting...you can wobble the NVA back and forth and see the needle tip moving inside the venturi. This can't be good! I tried the seal-it-with-fuel-line trick and it helped, but still pretty erratic. I'll be needing one of those new venturis. Or I'll have to make my own. But there's no way I'll use the stock carb, wired open or otherwise. Anyone wanna buy it off me?
Larry,that's a nice looking venturi set up - looks the part and like it belongs.
Doug Galbreath and Larry Driskill both have some smaller needle valve assemblies that are at least available. I still have a small (very small) stash of small OS needle assemblies but when gone will be gone. Trouble with trying to shop around is that a picture may be worth a thousand words but if the critical dimensions are missing or some sort of reference is given, you really have a clue on how "big" or "small" the thing is short of buying one of each and sorting through them.
Yes, the needle assembly is big, but it is what Eric stocks, and thus, what I designed around. What the heck, it works beautifully. For improved performance, I suspect a smaller diameter spraybar would be a good thing, but I would have to start development all over again! Even so, the Tee Dee carb setup will probably always be the ultimate choice for top performance.
I disassembled the carb tonight and modified it, put a washer shim on the needle side to tighten against, locking it wide open and trying to stabilize the assembly. Still, even with the fuel line seal, the needle can wobble inside the jet, seems like the male threads are a little undersized or something...but it is better, I'll try running it tmw and see if there's any improvement. Seems a shame to put such a cruddy little carb on an otherwise really nice engine.
Hey Ray, try some teflon tape on the threads of the needle valve. We used to do on the Tee Dee needle valve/body when we used them in F2C years ago. DOC Holliday
Well Duh, why didn't I think of that...I can make the threads as tight as I want, that should take most if not all the wobble out. Thanks Doc.
Was going to continue the break in of my AP Wasp, but found one of the carb retention screws was missing!
Haven't checked to see if it backed out during previous bench running, or simply sheared off. I torqued them down as much as I dared for that size screw, so I think re-tapping for a larger screw size is the next step.
Go to your local Ace Hardware and check out their machine screw bins. Take your engine with you. That is where I get mine when I am in a hurry or it's metric. DOC Holliday
Loosening of those screws is a problem. They are 2mmx.4mm, 2.5mm long. I think you can drill and tap for 2x56, or just drill and run a 2x56 bolt all the way accross the venturi. I may try that. Definitely use locktite!
Larry,
Thanks for the screw size info. H^^
I'll check ACE for the screws, as I noticed some really small metric sizes there.
The case is drilled large enough for a 3X48 screw to pass through (with room to spare), but a 2X56 should be more than adequate, and won't require drilling out the carb screw holes.
Out of curiosity, I pulled one of the venturi retaining screws out of a Norvel, and found it's the same thread size. The Norvel screws go all the way through, and use a nut on the other end.
I was going to check the fit of a Norvel carb/venturi on the Wasp case, but they apparently used some adhesive to hold them in place, in addition to the machine screw.
I am finding that at the rpm I run, glue and screw would be a good thing!
The Wasp carb is now mounted with a 2X56 machine screw, with a little coaxing from my tap to chase the threads in the carb base. Found there is no room for much of anything under the throttle arm, so I ran the screw in from the other side, and locked it snug with a thin 2X56 nut. There isn't even room for a washer under the nut, but I think it will hold.
Next time I try this, the throttle arm will be removed first! HB~>
Hope to run it again tomorrow, to see if it stays in place. Also want to see if performance is effected by the screw through the carb base.
Since all the later Norvel engines use a 2mm screw straight through the carb base, and they run circles around the Wasp engines, I don't expect to see any effect at all.
Ran the Wasp several times today, and it runs fine with the 2X56 bolt Through the carb base!
I did notice that the needle valve is still sensitive to movement, which I thought had been improved by the fuel line under the needle. Pushing down on the adjustment knob as before still had little effect, but pushing up, forward, or back, had a very pronounced effect on engine speed! HB~>
Oh well, that much more to be gained with a fixed venturi.
Bill, that is what I had found too, the thread tolerance is just not close enough to prevent the needle from wobbling in the jet. It was suggested that a guy could wrap the threaded portion with teflon tape. I haven't tried that yet but intend to, it's bound to at least help. What we really need is a better NVA. I believe that's being developed as we speak (write, type, whatever).
Ray,
I'm not sure that tightening the needle valve threads would be enough. On my particular engine, the rotor is a sloppy fit in the carb body, so I would have to fix that source of air leaks as well.
Hope Eric can market Larry's venturi design inexpensively. Other than that, he could reverse engineer the Norvel venturi design, and sell enough extra needles to Norvel owners to make them more cost effective. ;D
Anyone tried a Norvel venturi in a Wasp yet? My Norvel venturi all appear to be cemented in, and I'm reluctant to pull one.
I think the Norvel venturi is flattened where it inserts into the case, whereas the Wasp is round. Don't think it would fit. (I knocked one of mine out in a crash once. Definite, significant flats on 2 sides.)
Ray,
It was just a thought, but the Norvel venturi is nearly impossible to find anyway, so no big disappointment.
Checked ACE Hardware today, and they have lots of 2mm screws, so replacements for the Wasp carb will be no problem for you folks.
