  • August 02, 2025, 04:26:07 AM
Author Topic: 1/2A Flying Supply Dealer/Mfgs  (Read 2490 times)
Offline Jerry Bohn
  • ACE
« on: September 08, 2007, 07:17:58 PM »
I purchased a Cox Baby Bee from a local hobby shop but they had no other supplies for 1/2A. I received a "Stunt Trainer" from Blackhawk Models but they did not have every thing I needed.
Is there a "1/2A AM US" type distributor on-line.
I live 40 miles North of Denver if anyone knows of a LHS there that has everything and choices of stuff a guy needs to fly 1/2A planes.
Appreciate any assistance, Jerry Bohn
Jerry Bohn
Offline ray copeland
Re: 1/2A Flying Supply Dealer/Mfgs
« Reply #1 on: September 08, 2007, 07:34:42 PM »
Jerry, i don't know anything about the Denver area, but if i knew more about what you need maybe i could help. I patch a lot of "stuff" together to fly my 1/2a's. Ray
Offline Jerry Bohn
  • ACE
« Reply #2 on: September 08, 2007, 08:03:12 PM »
Ray, I'm immediately looking for lines/handle, glow connector, fuel, and props, primarily just to get my first plane, Blackhawks, "Stunt Trainer" off the ground. Also for the future just about everything including, kits and engines.
Jerry Bohn
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #3 on: September 09, 2007, 06:19:10 AM »
Here's some of what you're looking for:
http://snipurl.com/9igp
--Ray
Minnesotamodeler
--Ray
AMA902472
Offline Clancy Arnold
« Reply #4 on: September 09, 2007, 06:43:51 AM »
Jerry
Any thing you still need after what Ray can supply, you should try John Brodak's for the remaining items.  I have bought flying lines, starter clips and wheels from John.
I like to make my own handles.  (I wonder why?)
Clancy
Clancy Arnold
U/Tronics Control
« Reply #5 on: September 09, 2007, 07:11:13 AM »
Jerry, this is my starting setup. Super glue reinforement to sides of Sullivan clip. Battery box is from Radio Shack, uses 2AA for 2.4 volts, hot enough to get a flooded engine going but not enough amps to hurt the glo plug. I use rechargeable camera batteries and have used this set up all summer . The battery box needs a few drops of epoxy for support on the weak parts inside, obvious when you remove the cover. DuBro also made a Kwik Klip for 1/2a if you can find one. They stay on good, too good for me with engine running!
Offline Jerry Bohn
  • ACE
« Reply #6 on: September 09, 2007, 08:36:44 AM »
Thanks for the info and advice, thats what I needed.
Jerry Bohn
Offline LARRY RICE
« Reply #7 on: September 09, 2007, 12:49:32 PM »
Sig Mfg. and Brodack both offer 1/2a supplies by mail and sell on line. How did you like the kit?
Larry
Offline Jerry Bohn
  • ACE
« Reply #8 on: September 09, 2007, 05:49:54 PM »
Larry, Great kit, got about 1/2 build this week-end. Didn't have a lot of building time.
Town is celebrating Octoberfest and today, I flushed out two cars and put in new antifreeze after working out at the gym this morning. Will work on kit in the morning ,don't have to be to school custodian job till 2:45pm.
"Stunt Trainer" kit is just what I was looking for.
Jerry Bohn
Offline Jerry Bohn
  • ACE
« Reply #9 on: September 15, 2007, 01:49:50 PM »
I wound up ordering a 1/2A Flying Kit from Brodak, it had fuel, handle, lines, fuling syringe, control horns, glow connector and linkages. Good enough for getting everything I need to get flying. Kit had everything I needed, one stop shopping, just like I was looking for. All for $20. If I get into more 1/2A's I think I would start to gather better supplies as I learn more.
Jerry Bohn
