CLICK HERE--><--CLICK HERE
Those Sig 1/2-A Wheel Retainers
Started by Tim Wescott, August 09, 2025, 10:32:03 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Tim Wescott
Does anyone know if there's a source for the little spring wire wheel retainers that Sig used to sell?
I loved those things, but when Sig discontinued them I couldn't find anything like them.
Even a search term would be good -- then I could look for them.
  Are they like the ones that perfect used  to sell? Those turn upon eVilBay in collections of hardware and such. If you have a good example, you might try winding one yourself from .015 music wire or maybe smaller diameter. You just need a mandrel about half the diameter you want them to finish out at. The springs that are in oil seals might be salvageable to make some from also. I don't have any access to those any more.
  Type at  you later,
Dave Rigotti
Dave Rigotti
AMA 66859
Chesterland, Ohio
Tim Wescott
Dave Rigotti
Dave Rigotti
AMA 66859
Chesterland, Ohio
Tim Wescott
Quote from: Dave Rigotti on August 09, 2025, 02:41:56 PM
Is this a trick question?
Nope.  I've spent zero time with slot cars that weren't store bought, and that was more than 50 years ago.
944_Jim
#6
Just in case one wanted more answers sprung on one self;
https://www.coxengineforum.com/t7215-wheel-retainers-for-small-models
You want to go down about half-way. Roddie found a bag for cheap in Amazon (I think). Sure one needs a pair of dykes to do the finish work, but this is a bag of 100 pieces!
I also noted the Slot Car store also sells lead-out wire eyelets. They just don't call them that. Go up a few menu slots above the wheel retainers. Look at all those bellcrank bushings too!
https://slotcarstore.net/subscribe/show_cat.php?subcategoryid=2052&db_type=
Time to burn the wallet!
Tim Wescott
I had forgotten the fuel line trick.  I only remembered because I went to harvest a nice wheel off of a plane that I haven't flown in ages, saw it, and kicked myself.
Dave Rigotti
Dave Rigotti
AMA 66859
Chesterland, Ohio
Dave Rigotti
No muss, No fuss....
AND look GREAT too!
Dave Rigotti
AMA 66859
Chesterland, Ohio
