Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 15, 2025, 08:43:47 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
1/2 A building.
(Moderator:
Joey Mathison 9806
Tee Dee with tapped backplate
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Tee Dee with tapped backplate (Read 1547 times)
Jim Roselle
Guest
Trade Count:
0
on:
July 17, 2013, 05:38:57 PM »
I recently purchased a Tee Dee .049 with a tapped backplate. I run surgical tubing bladders and love the performance, I have never used crankcase pressure. What advice can anyone give on running with crankcase pressure. Can I use a drilled out Venturi? I have several small perfect tanks I could use.
Thank you,
Jim
Logged
Jim Thomerson
Trade Count:
0
Admiral
Re: Tee Dee with tapped backplate
Reply #1 on:
July 17, 2013, 07:46:31 PM »
Tapped backplate runs fine, you can open the venturi. Recommend a one way valve in pressure line, and uniflow tank. Suggest you stay with bladders if they work to suit you. Just plug the tap. There may be a one way valve in the tap.
Logged
Larry Renger
21 supporter
Trade Count:
0
Admiral
Reply #2 on:
July 18, 2013, 08:49:38 AM »
I agree with Jim as far as he went.
Personally, I prefer the crankshaft timed pressure output. That funny nipple on the side of the crankcase can be drilled out, and gives non-flooding, gentle pressure fuel feed.
Logged
BTW, Dracula Sucks! A closed mouth gathers no feet!
Jim Thomerson
Trade Count:
0
Admiral
Reply #3 on:
July 18, 2013, 10:39:54 AM »
I would think the crank pressure would give more pressure than backplate pressure. Backplate pressure changes from positive to negative, and back again as the piston goes up and down. Crank pressure should be timed to give only positive pressure. I always cut the nipple off as it gets in the way of my motor mounts.
Logged
Larry Renger
21 supporter
Trade Count:
0
Admiral
Reply #4 on:
July 18, 2013, 11:18:10 PM »
I never did the measurements, but was told that the place where the pressure port is located yields only a little positive pressure feed. You can select how much pressure you want by where in the stroke you locate the port.
Logged
25 supporter
Trade Count:
0
Admiral
Reply #5 on:
July 20, 2013, 10:07:20 PM »
My theory of crakcase pressure is this:
On the downstroke the piston sends A LOT of pressure into the tank.
On the upstroke it sucks a lot of air in through the venturi and allows a minimal amount of pressure to escape the tank.
But the net result is still PLENTY of pressure in the tank.
More than enough to drown any engine in fuel, even with a giant venturi.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
1/2 A building.
(Moderator:
Joey Mathison 9806
Jump to:
=> 1/2 A building.
