Building Tips and technical articles. => 1/2 A building. => Topic started by: Larry Renger on March 17, 2010, 08:17:53 PM
Well the model is toast. At least I got to fly it AT VSC, if not IN VSC competition. The model was flying great and I had a handle on getting a full pattern in.
Unfortunately the elevator clevis broke .... for the 3rd time! The first two times it went splork into muddy grass with no damage. No such luck here in Tucson. That dirt is dry and REAL hard. To quote James Bond, once is happenstance, twice is coincidence, but three times is enemy action!
I have a well balanced engine and prop, but there is a resonant mode in the model that will destroy a nylon OR steel clevis in 4 or 5 flights. I will build another one with lots of attention to structural dampning.
One amazing thing is that, except where the wing came completely off, through all 3 crashes, the Coverlite covering didn't tear. The wing left on the plane has the covering intact, the torn off wing only has torn covering where the balsa parted under it.
Sounds to me like a resonance (bending mode, probably first mode) of the pushrod. Lighten it, shorten it, or put a fairlead in the middle comes to mind.
It is a carbon fiber tube. Shold be a very high frequency for the resonance and good dampening. Plus, I could feel the vibration at the handle and hear when it was goin on.
I don't think the problem is the engine, but I will put it on another model to find out.
Since the ends are breaking the mass of the tube is too great, and the strength of the ends isn't enough to support it when it resonates.
To dampen the motion of the tube in the transverse direction, a fairlead would do that.
To change the resonant frequency of the tube dampening or reducing the mass are the easiest things to do. Shortening the tube itself would lower it's weight and increase it's resonant freq.
Add some strength to the clevises, if the clevises on the end are the small thread ones, go to the 4-40 / 3mm ones to get some more strength or change to ball fittings if there's room for them.
I like this one the best. This proves once again that *clevises do not belong on stunt planes*. Even teeny ones.
I have and still do use clevises for many years on 1/2A planes with never a failure until this model. It is not likely a problem with the clevis strength, but with some specific resonance in this design. I plan to build a new one and add better dampening to the nose section, 3/32 balsa instead of 1/32 ply doublers.
