  • June 16, 2025, 08:48:06 PM
Author Topic: TD .049 venturi size  (Read 1728 times)
Offline Robert W
« on: October 28, 2008, 11:56:07 AM »
I did a quick search and may have missed this, but I am looking for what is a good ID size for the venturi on the TD049 that will give good performace on suction from a uniflow tank. The math I use for the larger engines would require an opening smaller then what is on the reed valve motors, so I do not trust the math for this size.
I am trying to get some of my 1/2A planes running better.
Robert
AMA 28627
Online James Lee
Re: TD .049 venturi size
« Reply #1 on: October 28, 2008, 02:44:09 PM »
Robert
Way back when we were doing Tee Dee 1/2 A stunters the early Tee Dee venturi with the .125 (app) hole worked the best...    FWIW
thanks
Jim
Offline Larry Renger
« Reply #2 on: October 28, 2008, 07:46:01 PM »
Why suction?  The side nipple pressure works really well.  Take a 2x56 "T" nut and turn the flange down to make a nipple out of it.  Screw it onto the side nipple on the carb housing with a bit of epoxy or Goop adhesive to assure a seal.  Drill the pressure tap per Cox's instructions and plumb to the tank.  I get incredibly good, reliable runs with this setup.  You can even drill out the venturi a bit if you need even more power and can handle the fuel load required in your plane.
Offline Robert W
« Reply #3 on: October 29, 2008, 06:50:37 AM »
Thanks for the information, I measured the one I have been using with a drill bit and it is around 0.108". I will keep experimenting till I get good runs.
Robert
AMA 28627
Offline John Rist
« Reply #4 on: October 30, 2008, 12:33:38 PM »
I have a Madallion .049 that I run on pressure.  I have trouble keeping the fuel line on the pressure tap. Is the above a fix? do you have pictures?  #^
As a side comment I have found pressure hard to hand start but an electric starter works fine. H^^
Offline Jim Thomerson
« Reply #5 on: October 30, 2008, 03:56:51 PM »
I flew 1/2A stunt with TD on a pacifier tank or with crankcase pressure off the backplate.  Do not flip a TD.  Headprime, turn the prop backwards to vertical, attach glow plug and hit the prop forward with your gloved finger.  With practice it works almost every time.
« Reply #6 on: October 31, 2008, 09:01:22 AM »
To John Rist:  see above for the best way to keep the hose on the nipple.  There are a couple of other ways as well.  One way is to super-glue the hose on.  Another is to gently scribe anullar lines around the nipple with a #11 blade.  This adds friction to prevent slippage.  The 2x56 nut filed down to become a real hose nipple is far and away the best.
Offline John Rist
« Reply #7 on: October 31, 2008, 12:19:41 PM »
I am fairly new to U-Control BBs.  It never ceases to amaze me what can be learned on one.  Thanks all!! y1
« Reply #8 on: November 02, 2008, 07:39:14 PM »
Here is a photo of the nipple modification I use on the Tee Dee and Medallion.  You screw a 2x56 "T" nut onto a bolt and chuck it into your power drill.  Use a file to cut the flange down until it is a nice hose nipple shape.  It will then screw onto the plastic nipple on the carb housing of either engine, and if you use a bit of Goop, epoxy, or JB weld, will seal perfectly.  Drill out the tap per factory instructions, and you have a very reliable pressure tank drive system.
I like the ultra fine control that the Kirn or Klaus needle system provide, but it is quite workable with the stock needle.  I seem to need about 1 ounce of fuel to do the classic pattern on 42.5' lines with a bit of margin left over.  I do tend to set it screaming all the way, keeping attention on not going over-lean on the verticals and overheads.  If you want something closer to a 4-2-4 break, you will need a bigger tank.  Currently, I like the APC 6x2 prop to give me lap times in the high 4-second region.
