  • June 17, 2025, 06:10:19 PM
Author Topic: NEW TYPE OF CONTROL LINE FLYING  (Read 2661 times)
Offline LARRY RICE
« on: June 03, 2011, 07:44:39 PM »
  I have always been interested in how control line flying survived the war years.  I found out about "Whip Powered Control Line" a few years ago and we produce a few kits of that type.  Then I learned about rubber powered control line.  Companies line Scientific Models produced control line kits that operated on rubber power.  When I got flight reports back on our new free flight rubber powered kit (Golden Falcon) of over 2 minute flights it all seemed possibable.  We will be testing this out with a Golden Falcon and I am interested in what you think about it.  I am also looking for ANY plans for Rubber Powered control line models.
Thank You
Larry
Offline Douglas Ames
Re: NEW TYPE OF CONTROL LINE FLYING
« Reply #1 on: June 04, 2011, 03:30:58 PM »
Guillows, maybe? Seems like they were involved in everything - Model Aviation.
An Old Timer high wing (F/F) kit with mods for C/L sounds like a nice project for somebody. It would have to be light, no dihedral with lots of rudder for line tension. Centrifugal force just wouldn't be there at that speed.
AMA 656546
Offline Jim Thomerson
« Reply #2 on: June 04, 2011, 04:19:20 PM »
I have plans, maybe in a Flying Aces magazine, for a rubber powered control line model.  I saw, at a distance, a rubber powered CL model fly at a past Vintage Stunt contest.  I thought the same one I have plans for. As I recall it made maybe about a lap and a half before running out of power.
I also have plans somewhere for a freeflight model converted to control line.  This kind of airplane was called a "Goat".  The St Louis SAM club has a contest in October which includes CL slow flight.  It requires a Goat airplane, but I don't know the rules beyond that.  I think winning speeds are in the 20 MPH range.
I've never built a successful rubber powered airplane, so what do I know?  I think one would have to go to a geared motor to get a long enough motor run to be much fun.
Anyway, I'll see if I can find the plans and will send them if I do.
Offline LARRY RICE
« Reply #3 on: June 04, 2011, 07:16:16 PM »
Thanks, plans is what I need.   H^^
This is the model we will be testing it on, the "Golden Falcon".
Larry
« Reply #4 on: June 05, 2011, 07:38:44 AM »
There is a huge British literature on round-the-pole flying with rubber powered airplanes.  People have also done it with 1/2A airplanes.  I have an article on R/C control line with 020 engine.  It used a receiver and servo on a rotating disc on top of a pole, The servo acting as the control handle as we think of it.
Offline PerttiMe
« Reply #5 on: June 05, 2011, 12:26:30 PM »
There's plans on the internet for Stanzel Tiger Shark (with engine) and Shark P-60 (rubber): "G Line" speed planes. I think G Line does not give all that much control.
http://www.rcgroups.com/forums/showthread.php?t=1276819
http://www.rcgroups.com/forums/showthread.php?t=1262627&highlight=shark
Offline PerttiMe
« Reply #6 on: June 05, 2011, 01:23:20 PM »
I went crazy browsing... and found "Complete Construction Data That Will Enable You to Build the Fastest
Model in the World" from 1936, on theplanpage.
Not control line at all but a rubber powered design that went up to 60 mph.
Article and plan in the attached PDF
« Reply #7 on: June 07, 2011, 04:39:02 PM »
 Larry, I found the rubber powered CL model in the first magazine I looked at.  Flying Aces, June 1942.  I'll send you the magazine assuming I can find your mailing address (shouldn't be too hard).
Offline LARRY RICE
« Reply #8 on: June 07, 2011, 04:42:44 PM »
Thanks Jim, my address is:
Black Hawk Models
300 East Arbor Street #42
Long Beach, Ca. 90805
I will be very very pleased to see the article.
Larry
« Reply #9 on: June 11, 2011, 08:56:06 PM »
Larry, magazine and copies of a couple of articles from Aeromodeller in the mail yesterday.
Offline LARRY RICE
« Reply #10 on: June 11, 2011, 08:58:06 PM »
Thanks, Jim, I'll see that you get them back.
Larry
Offline LARRY RICE
« Reply #11 on: June 13, 2011, 06:30:56 PM »
GREAT MAGAZINE!!!!
THANK YOU, JIM!
LARRY
