  • June 19, 2025, 02:37:54 AM
Author Topic: T D glo plugs  (Read 2465 times)
Offline Bootlegger
T D glo plugs
« on: April 03, 2011, 12:49:20 PM »
   To the guy's that are running Cox engines, what glow plugs are you using.?  Regular or high compression?  I am using 25% nitro fuel and regular plugs, but I need a little more power.
   Line size is .008 about 35 feet long in an engine that came out of the Stuka stunt plane simular to the Chipmont of the seventies.
   Any suggestions sure will be appreciated.
   Also what prop are you using and w here do you get them
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: T D glo plugs
« Reply #1 on: April 03, 2011, 01:56:27 PM »
I get a lot more reliable run from lower nitro fuel with a higher compression head.  More power, too.
I decided I was going to experiment, and made a high-compression head to take short glow plugs.  I got it high enough compression that without extra gaskets I could hear the detonation on regular fuel.  That's a great head for flying on the same fuel that I run in my fuller-sized planes, but if I put 'regular' 25% nitro fuel in the tank it turns into a machine for burning out glow plugs!
Offline Bootlegger
Re: T D glo plugs
« Reply #2 on: April 03, 2011, 03:00:53 PM »
   Can you share more info on the short plug set up you are running?
 Thanks for your answer...
Gil Causey
AMA# 6964
Online kenneth cook
Re: T D glo plugs
« Reply #3 on: April 03, 2011, 05:14:51 PM »
          I've done extensive experimenting with all types of plugs for the TD. I can say the Cox 1702 high compression plug is good a bit pricy and the duration is poor. I run 35%-40% nitro daily. I use no less than 3 shims when using the high comp head. Tim stated it perfectly the plugs are going to get destroyed. Remember, higher nitro , more shims. The Merlin plugs work very well, although without enough shims the engine becomes over compressed and very hard to start. These plugs can require 4-6 shims. The Merlin plugs are very economical and work well assuming you have the proper head clearance with shims. The Glo Bee plugs work well if you can find them except reliability falls off real fast with these, you either have a good one or a poor one. These seem to make the engine run faster than any plug I've ever used. There is 2 types of Glo Bee plugs, the racing style and the sport. The racing looks just like the head shape of the Cox high comp head. The sport has a very shallow trumpet like sphere to it. I've had to use as many as 7 gaskets with the sport type. I would try and avoid the Glo Bee plugs just due to the complications and unavailability. The Galbreath Nelson head is a very good alternative. The conversion head is about $15 while the plugs run you another $5. These work excellent and require additional shims about 4 of them. The plugs are more forgiving to lean runs and are very durable. The major draw back is the larger plugs base which requires a different clip. I use a large alligator style as opposed to the Cox style on a 6' lamp cord. This works well. Don't use old glow plug shims as they're already crushed and will cause the head to come loose constantly. Tuning with the shims takes a bit of patience but pays off in the end. I use smaller props than what I typically used when I was first learning. I used to use the old faithful 6x3's, I now use mainly 5x3's as I found the APC 5x3's to work very well for me. The drawback is price. Those props can be as much as $4 a piece. The Cox 5x3 is still available through Xenalook from Canada. These work well and can be purchased in bulk. There are 6x2 Cox props as well. There are a variety of APC props to suit your needs. The APC 5.7x3 is an excellent all around prop. You just need to experiment. Ken
Offline Bill Adair
  • AMA 182626
Re: T D glo plugs
« Reply #4 on: April 03, 2011, 05:26:39 PM »
Hi Gil,
Lots of choices out there, but the most bang for the buck is from Al Kelly at Merlin plugs. You would want the 2019A package, with three hot plugs, and a Norvel type clamp ring, for only $14.95.
http://merlinglowplugs.com/main_page.html
I've heard great things about the Merlin plugs, so I ordered that set for my Cox and Norvel engines.
My Tee Dee .049 runs great on Sig 10% nitro, with 25% Castor oil, and a Cox (Bernie) 5X3  "Rubber Ducky" prop. I eventually crashed the Flight Streak straight into the ground, but the engine and prop were not damaged (not so for the plane).
Offline Larry Renger
Re: T D glo plugs
« Reply #5 on: April 03, 2011, 06:43:07 PM »
I lidke the Merlin plugs too.  For use with a reed Cox engine, I would use 3 to 5 gaskets to control the compression.  If the engine tends to stop and just bat back and forth, it is overcompressed.  Otherwise, reduce the number of gaskets until it will only just run right.  For short duration free-flight, you can use very high nitro.  For CL stunt, I would not go over 15% nitro and a minimum of 20% oil, preferrably half castor, half synthetic.
Adapters for conventional plugs are fine for sport flying, but not for competition use.  They cost power and reliability.  The problem is that the shape of the combustion chamber is totally ruined by the position of the plug and the threads that are exposed to the combusion chamber.  Also those plugs seat at the top of the threads, so who knows what the compression ratio is?  By substituting a Merlin Glowbutton for the regular plug in a Brodak MK 1 .049, I gained 1500 rpm and the run was MUCH more stable.  The Nelson head added ANOTHER 1500 rpm beyond that!  These changes turned a casual sport engine into a competitve tiger!
My standard setup for 1cc stunt is the AP Wasp .061 engine, modified with the Jan Holuszko (do a search for his contact info) venturi and Merlin glow button with 1 or more extra gaskets, depending on the Nitro and prop I am using.  Other than that, the engine is totally stock and turns about 21000rpm on the ground with an APC 5.5x2.5 prop.  My new model, the Sky Streak (search again) is actually going too fast on 48' lines.  I will cut the Nitro down to 7.5%, and may try the 6x2 prop to make the speed liveable.
Re: T D glo plugs
« Reply #6 on: April 03, 2011, 07:31:48 PM »
Not much -- I can't find my sketches, so I can't show you the head.  It's just as well, because with the exception of raising the compression and making sure that there was something resembling a squish band, there's nothing special about this head.  It's got a threaded bit that screws into a Cox 049 cylinder, a level bit that squeezes a Cox 049 head shim, a step about 0.01 or 0.015 inches deep and 0.03 inches wide (for squish), then a ramp about 0.1 inch up to a 1/4-32 hole for a glow plug.  On top it's got fins, and a slot for a head wrench.
Basically, I took some aluminum, and carved away everything that didn't look like a head.
All the advice that I've seen on these things includes "don't bother with a regular RC glow plug", and that's exactly what I'm doing.  One day I'll get some Nelson plugs and a tap to go with 'em.  Then I'll make the right shape of tapered reamer and I'll make another head or three.
Offline Steve Thornton
Re: T D glo plugs
« Reply #7 on: October 01, 2013, 10:46:46 AM »
I have attempted to post this pic, but too large, so I'll try again!  This is my White lightning and I finished it with Rustoleum rattle can over light silk span.  It weighs 10.05oz with the TD .051, 3/4 oz tank, and I would like to know if this is too heavy.  I will build a second one now that I have learned a few things, and I will follow your advice Bruce, and use dyed tissue instead of "weight in a spray can."  I would also like advice on wood selection for the wing because I seem to have some small twists in mine. Hope it will fly okay-if not I will let my grandsons use it for another trainer.
Thanks guys,
"Most of us won't make it out of this world alive."
Steve Thornton
Re: T D glo plugs
« Reply #8 on: October 01, 2013, 10:52:47 AM »
Sorry for posting in the wrong place, I had tooo many tabs open and not enough coffee.
Steve Thornton
Re: T D glo plugs
« Reply #9 on: October 01, 2013, 01:11:48 PM »
That's okay Steve, I enjoyed reading the old thread about my favorite little engines. Maybe the Mods will move it to 1/2A.
Nice plane. And, no, 10.5oz is fine for a Tee Dee powered plane, it should burn up the circle pretty well. As for the wood question, I'll defer to our more skillful builders.
Rusty
Offline Andrew Tinsley
Re: T D glo plugs
« Reply #10 on: October 06, 2013, 04:22:27 AM »
I can confirm the Merlin Combo is a very good set up. The Galbreath head and Nelson plug is even better, though more expensive. The Nelson plugs are virtually indestructible, so that solution may be cheaper overtime! Low nitro fuel works well with either of these high compression heads, although not giving ultimate power.
  The above will give anyone more power and much cheaper running costs than the standard TD head, in my experience. The note of caution about not using used head shims is correct. However if you heat them up to red heat (gas torch) and let them cool then they CAN be reused safely. Remember that they will be slightly thinner after this cheapskate trick.
Andrew.
BMFA Number 64862
Offline Mike Scholtes
Re: T D glo plugs
« Reply #11 on: October 07, 2013, 10:31:21 PM »
I have two TeeDee 049s with the Galbreath-Nelson head used in free flight. One has the same plug I installed in 1998, hundreds of flights on 35% nitro fuel. Seems indestructible if the glow igniter voltage is kept within limits (IOW don't burn out the plug!). Don't use any extra shims. I think over time (even a short time) this comes out as the least expensive AND best performing option.
Re: T D glo plugs
« Reply #12 on: October 09, 2013, 01:16:02 PM »
Hi Mike,
I couldn't agree more, I have yet to burn out a Nelson plug, so this is the best and cheapest way to go in my experience. If on the odd occasion I run high nitro fuel. I do need extra shims. Must be a function of individual heads having somewhat different compression (head volumes)?
Andrew.
BMFA Number 64862
