  • July 07, 2025, 04:29:09 PM
Author Topic: Stuntman 23 plans  (Read 4979 times)
Offline Tim Chenevert
Stuntman 23 plans
« on: January 13, 2018, 08:16:38 PM »
I am kinda kicking around with the idea of building one of these. I called my LHS and they did not have the old kit in stock. So I am looking for full size plans to scratch build one. Can anyone suggest  a site for plans? I built one with a Baby Bee when I was a kid, a long time ago, but thinking about a Golden Bee or a Black Widow for power. Thanks, Tim
Baton Rouge Bi-Liners
AMA 179681
Re: Stuntman 23 plans
« Reply #1 on: January 13, 2018, 09:40:42 PM »
Brodak sells a set of planes here:
http://brodak.com/1-2a-stuntman-plan.html
Mark
Offline pat king
    • PDK LLC
« Reply #2 on: January 13, 2018, 10:10:54 PM »
The Brodak 1/2A airplanes are designed for beam mount engines. You will have to adjust the design for a radial mount engine.
Pat
Pat King
Monee, IL
AMA 168941
Offline 944_Jim
« Reply #3 on: January 14, 2018, 12:49:17 AM »
« Reply #4 on: January 14, 2018, 01:38:57 AM »
I tried the outerzone but did not scale out correctly. I wonder if a print shop could download it off my phone to the correct scale? Brodak uses a beam mount and I wanted to go old school with this one. I am not setup for the Cox .049 so just thinking about it. Tim
AMA 179681
Offline Larry Renger
« Reply #5 on: January 14, 2018, 08:39:25 AM »
Brodak sells a Nylon radial mount for Cox engines. Cut the front of the fuselage to the correct length and bolt it on. It even has grooves for landing gear mounting.
« Reply #6 on: January 14, 2018, 12:06:42 PM »
    It's the same as the old Midwest mount. Makes for a very clean mount and based on extensive testing, I can assure you it is very sturdy - sturdier than a Stuntman 23 fuselage!
Offline Target
  • C/L Addict
Chris
AMA 5956
« Reply #8 on: January 14, 2018, 12:27:42 PM »
I always keep a supply of the Brodak mounts for the .049 engines on hand for spurious projects.  Like Larry says, already has molded lines for the landing gear.  Has molded tabs for built-in right thrust.  Can be used for either tanked or horseshoe backed Cox engines (or engines sharing same bolt pattern).  I like them, and they'er cheap.  Saves a lot of building time.
That being said, you could just take the Brodak plans and cut the nose back to the desired length, then cut 1/4" balsa cheek blocks and ply firewall as shown on the Outerzone plans.  I've not looked at the Stuntman 23 plans, but other Brodak 1/2A plans show where to cut for radial mounted engines.
Mark
« Reply #9 on: January 14, 2018, 05:18:43 PM »
The Brodak mount is not the same as the Midwest. I designed it for John while I was at Cox.
Offline 944_Jim
« Reply #10 on: January 14, 2018, 10:26:23 PM »
You may need to try printing from a PC that has printer drivers that allow for "tile" or "poster" printing. Then play with scale up/down as appropriate.
This is another very similar plane...look for the Stunt Chimp
 trainer on this page:
http://nswbgmodelling.airleague.com.au/ControlLinePage/ControlLinePlans.htm
Offline john vlna
« Reply #11 on: January 15, 2018, 10:07:39 PM »
You can have Staples, etc print PDFs files full size at a reasonable cost. I use the , cheaper than buying ink, and you can electrically send the file to be printed.
Offline 944_Jim
« Reply #12 on: January 16, 2018, 08:51:57 AM »
The Stunt Chimp is already tiled...print full size, and tape the sheets together. No Financial Interest.
Offline Phil Krankowski
« Reply #13 on: January 16, 2018, 11:34:13 AM »
Most print shops and office stores that print posters can do scaling.  Talk to the person before hand and try to show up during a slower part of the day.
Locate key dimensions and have them written down.  A bit of math on the error and a reprint usually is all it takes.
OTOH, order the Brodak kit, and consult the outerzone plans for differences from the original, and trace your parts before building.  Brodak kits tend to be very well done.
Phil
Offline James Holford
« Reply #14 on: March 24, 2018, 07:36:47 PM »
Tim may I say if ya change ya mind on this project.
 Pat kings Baby Ringmaster is a great kit and flyer!!! Mine lasted one day! Never loop without speed haha.
 Also i have a link to some .049 combat planks that Charles in our club showed me... we were going to build a bunch and combat them.
 Just picked. Up a lile new Black Widow this week.
Jamie Holford
Lafayette, La
AMA #1126767
Offline Chancey Chorney
« Reply #15 on: March 25, 2018, 12:54:08 PM »
Here is a tiled copy of the Stuntman 23. To be printed on 6 'letter' size sheets.
« Reply #16 on: March 28, 2018, 05:29:48 PM »
I tried to open the site up but could not. Tim
AMA 179681
« Reply #17 on: March 28, 2018, 06:05:44 PM »
Did you try clicking here in the blue circle?
