Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
August 01, 2025, 05:13:24 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
1/2 A building.
(Moderator:
Joey Mathison 9806
Still on Medallion engines
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Still on Medallion engines (Read 2050 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
on:
September 02, 2021, 03:23:07 PM »
Guy's I have two medallion 09 engines that I can not get apart using the proper wrench, I can't get the front end to come lose to remove the shaft and other front end parts, it seems that both
of them are bound and will not unscrew I sure don't want to "bugger up" the case or shaft to open them up. I have done several medallion and T D engines the same way with no problem. I have mounted the block in a small vice but still can't front end to unscrew.. Any help/suggestions sure will be appreciated.. Much obliged...
Hope that I made myself clear...
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
kenneth cook
Trade Count:
0
Admiral
Re: Still on Medallion engines
Reply #1 on:
September 02, 2021, 04:37:22 PM »
Pour some lightweight oil around the lock collet and heat, heat , heat. Don't use a torch, use a heat gun. Use the smoking oil as a gauge as too how hot your getting it otherwise you will melt the carb body.
Logged
Bootlegger
22 supporter
Trade Count:
0
Admiral
Reply #2 on:
September 02, 2021, 07:50:24 PM »
Thanks a lot, will try that tomorrow..
Logged
Gil Causey
AMA# 6964
Bootlegger
22 supporter
Trade Count:
0
Admiral
Reply #3 on:
September 03, 2021, 04:44:17 PM »
Ken, I got to try your "trick' w/heat, and it worked like a champ, wanted to let you know, and say "much obliged" thanks again...
Logged
Gil Causey
AMA# 6964
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
1/2 A building.
(Moderator:
Joey Mathison 9806
