Building Tips and technical articles. => 1/2 A building. => Topic started by: Bootlegger on September 02, 2021, 03:23:07 PM
Guy's I have two medallion 09 engines that I can not get apart using the proper wrench, I can't get the front end to come lose to remove the shaft and other front end parts, it seems that both
of them are bound and will not unscrew I sure don't want to "bugger up" the case or shaft to open them up. I have done several medallion and T D engines the same way with no problem. I have mounted the block in a small vice but still can't front end to unscrew.. Any help/suggestions sure will be appreciated.. Much obliged... H^^ D>K Hope that I made myself clear... HB~> HB~> HB~>
Pour some lightweight oil around the lock collet and heat, heat , heat. Don't use a torch, use a heat gun. Use the smoking oil as a gauge as too how hot your getting it otherwise you will melt the carb body.
Thanks a lot, will try that tomorrow.. H^^
Ken, I got to try your "trick' w/heat, and it worked like a champ, wanted to let you know, and say "much obliged" thanks again... H^^ :!
