  • July 07, 2025, 05:03:51 AM
Author Topic: Some "Youngsters" May Recognize This Design  (Read 4239 times)
Offline Dennis Saydak
« on: April 14, 2018, 07:12:13 PM »
I haven't built a 1/2A model in many years. About two years ago I built this wing and then hung it up. I'm waiting for warm weather so I can paint some unfinished projects and decided to frame up the fuselage today. It's "scratch" built from plans, not a kit. It will have a Holland Hornet for power, which I got from Dankar in Tucson a few years ago.
Offline Bootlegger
Re: Some "Youngsters" May Recognize This Design
« Reply #1 on: April 14, 2018, 07:23:23 PM »
 Dennis I saw one many moons ago, and I ain't no youngster, but what I see looks real good and I'd like to see it when you get it finished... LL~ LL~
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline RK
« Reply #2 on: April 14, 2018, 09:38:14 PM »
My vote is for a 1/2A Snapper! Built one many years ago!
RK Flyer
If you come to a fork in the road,,,,Take it!
« Reply #3 on: April 15, 2018, 07:24:23 AM »
"Many Moons Ago" and "Snapper" are incorrect.
Hint - it was kitted by Guillows and the plan is laid out for clockwise flight.
« Last Edit: April 15, 2018, 07:44:58 AM by Dennis Saydak »
Offline Larry Renger
« Reply #4 on: April 15, 2018, 07:40:07 AM »
Baby Barnstormer, and the Holland may be a bit much. It was flown with an Atwood Wasp. The Holland is WAY more powerful and a lot heavier.
Great looking construction, though. Keep those photos coming!
« Reply #5 on: April 15, 2018, 07:51:25 AM »
The Bingo award goes to Larry. The construction is quite involved for a 1/2A model (especially the wing). It was a lot of work.
I don't have a Wasp or lower performance 1/2A engine so it may just wind up as a Hanger Queen.
« Reply #6 on: April 15, 2018, 02:28:50 PM »
... so it may just wind up as a Hanger Queen.
Noooooo!!!!    :'(
« Reply #7 on: April 15, 2018, 04:13:24 PM »
Too easy as it says Baby Barn in the link below the pic.   Love the construction. S?P
« Reply #8 on: May 06, 2018, 04:58:00 PM »
I did a little more work on this project recently. I have the wing nicely fitted to the fuselage and the tail feathers are cut out. The L.G and tank floor are also installed.
Before I can go much farther I need to decide on what engine to use. I don't have a Wasp or other suitable .049 and I don't want to spend big bucks buying one from fleabay. I do have NIB Pee Wee .020s and a Tee Dee .020. Will either of these options be suitable to fly it? I don't have the 1/2A experience to know. .049s with beam mounts are generally too wide to fit between the sides. Thanks in advance for any advice.
« Reply #9 on: May 06, 2018, 05:38:04 PM »
Nothing wrong with using the engine have, sorry Larry.   Just go to a lower pitch.  A 6-3 should work great depending on length lines. H^^
« Reply #10 on: May 06, 2018, 06:18:39 PM »
John, I must agree that my Holland Hornet is too heavy for this model. I have located a nice Wasp .049 locally but it has the tank/back plate mount. I'd need to replace the tank with a standard back plate. Perhaps someone has a worn out or crashed Wasp .049?
Offline dennis lipsett
« Reply #11 on: May 07, 2018, 09:44:02 AM »
I built one of those a little over 60 years ago. Powered it with a first generation Wen Mac 049. I flew better than I could at the time and I have a picture of it somewhere in the dark musty archives.
« Reply #12 on: May 07, 2018, 10:14:33 AM »
"Wen Mac .049" Now that brings back some real memories - all of them bad!
« Reply #13 on: May 13, 2018, 10:29:34 AM »
A little more progress. Wing is glued into the fuselage, pushrod is installed & stab is hinged. Hopefully one more Saturday build session and it will be ready to cover. I'd like to cover it with Japanese tissue as I have lots on hand. The Big Barn Stormer was built by a club member.
Sheesh! this thing is as much work as the full size one. Smaller hands would have made things a lot easier.  ;D
« Last Edit: May 13, 2018, 05:01:00 PM by Dennis Saydak »
« Reply #14 on: May 19, 2018, 03:51:22 PM »
I've completed all construction except for the nose & engine mounting. I've located a Wasp.049 and I'm waiting for some parts from MECOA to convert it to C/L. In the meantime I'll put some clear dope on it  and get back to covering & painting my other winter build projects. The weather has finally warmed up enough for me to paint in the garage/outside.
Offline Bill Adair
  • AMA 182626
« Reply #15 on: May 20, 2018, 01:28:39 AM »
Dennis, I have a couple of Atwood .049 back plates. If those will fit the Wasp, they are yours for the asking. Need an address if you can use them.
« Reply #16 on: June 16, 2018, 08:37:27 PM »
Thanks to Bill Adair for supplying the Atwood parts I needed to complete this model. I now  have the engine mounted and the nose area done. I just need to fit the tank, close the top nose block, make a canopy and cover it. It's getting close and so are a couple of other projects I am working on (non 1/2A).
Offline Terrence Durrill
« Reply #17 on: June 17, 2018, 08:13:49 AM »
  I built my Baby Barnstormer in 1954 from a Guillows kit.  Power was an O.K. Cub .049 (marginal power).  It was the best half-A stunter I ever had.  It flew the maneuvers just like the big one which I built in 1987 with a Fox .35.  I was a great little plane !       D>K       H^^
