  • July 11, 2025, 10:53:09 AM
Author Topic: Sky Sport Mk II  (Read 3754 times)
Offline Larry Renger
Sky Sport Mk II
« on: February 01, 2009, 10:11:25 AM »
Well, I have finished and flown the second Sky Sport model.  It is painted with "Painter's Choice" enamels over Nitrate dope base.  I did have some cracking in the open bay areas, unfortunately.  The plane flies like a dream with smooth level flight, loops and tight square corners.  The added trike landing gear makes flawless landings easy!  Weight came out at 9.4 ounces, and the 180 sq.in. wing provides plenty of lift to handle it.  The weight also lets me use 50' lines, so lap times are comparatively relaxed.
Offline George
  • Love people, Use things.
Re: Sky Sport Mk II
« Reply #1 on: February 21, 2009, 09:11:23 PM »
Larry,
Nice looking plane, I like that trike gear.
I am unfamiliar with "Painter's Choice" enamels. Is this something you have used before?
George
George Bain
AMA 23454
Re: Sky Sport Mk II
« Reply #2 on: February 22, 2009, 10:12:43 AM »
Painters Choice is a discount version of Rust-Oleum paint.  It doesn't have the rust preventative power, but that is not an issue for our purposes.  It covers well and is highly fuel resistant to Nitro, good at least to 20% level.  It is nearly $1 a can cheaper than Rust-Oleum and made by them.
Offline Balsa Butcher
  • High Desert Flier
Re: Sky Sport Mk II
« Reply #3 on: February 22, 2009, 10:55:32 AM »
What great looking airplane Larry.  Now if you would slightly change its silohette and add round wingtips so that it would resemble an Ercoupe...  ;)
« Last Edit: February 22, 2009, 07:35:09 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
Offline afml
Re: Sky Sport Mk II
« Reply #4 on: February 22, 2009, 01:59:37 PM »
Great looking plane Larry!   y1
How is this one different from the first??
Tell us about your tank set-up!   #^
"Tight lines!"
Wes
Wes Eakin
Offline Bill Heher
  • Fix-it
Re: Sky Sport Mk II
« Reply #5 on: February 22, 2009, 06:08:37 PM »
Larry - I am curious about the tank set-up also, do the vent lines go through the fuselage to the inboard side? I don't see any in the picture.
Bill Heher
If it's broke Fix-it
Offline ray copeland
Re: Sky Sport Mk II
« Reply #6 on: February 22, 2009, 06:15:31 PM »
Larry, I am a huge fan of yours, but does the kit for this 1/2a really cost $80.00 plus shipping or am i looking at something wrong?  Thanks,, Ray
Re: Sky Sport Mk II
« Reply #7 on: February 23, 2009, 09:29:36 AM »
To answer questions in a couple of posts above:
The tank is a bladder that is contained in the cheek cowls.  No vents required.  The makings for the tank are included in the kit.  At first I used balloons, but now I am into re-configured plastic bags.  The tank is just an air free holder for fuel, no pressure is used.  There has been an extensive thread on construction and use of balloon tanks in this forum if you do a search.
The kit is pretty expensive, I admit, but it does include all hardware except the engine, lines and handle.  Tank, wheels, bellcrank, horn, all included in the kit.  A small model such as the SkySport has the same number of parts as a "big one" does.  Laser cutting is pretty time consuming, and cutting a 1/2A kit isn't any faster than a big model.  The laser machine is pretty costly, and uses a lot of power.  It seems to me that Eric charges something like $40/hour to do cutting for others (you would have to check with him to get the correct number, as I am working from memory here).
The differences in the second version are that the nose is 3/4" longer to both provide better balance and more volume for the fuel tank inside the cheek cowls and the change to tricycle landing gear.
I think the resulting model is worth it if you fly competition 1/2A.  Several national champions have flown the plane and approved of its performance.  Tony Naccarato even says it is better than the 1/2A Pathfinder!
Offline George
Re: Sky Sport Mk II
« Reply #8 on: February 23, 2009, 10:04:06 AM »
Larry,
If I remember correctly, Rustoleum uses a fish oil in their rust proof paints. Do you suppose that the "Painters Choice" excludes the fish oil, and perhaps the oil provided a "plasticizer"...which may have allowed the cracking?
BTW, although the red/yellow makes a beautiful plane, I still like the blue/cream on the first version. That was one fantastic shade of blue.
George
George Bain
AMA 23454
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Sky Sport Mk II
« Reply #9 on: February 23, 2009, 05:29:24 PM »
If there's a market for $80 1/2A kits I may reconsider kitting my LittleAxe.  My most expensive is $35, for a pretty simple plane. You're right, the little ones have as many parts as the big ones!  Never did kit the L-A because I didn't think anyone would pay what it would cost...Thinking about it, though, it might still be more than that $80 mark.  Oh well. Never mind.
Re: the paint, America's Best is another Rustoleum-produced economy paint.  It also works as well as the more expensive stuff.
--Ray
AMA902472
Re: Sky Sport Mk II
« Reply #10 on: February 23, 2009, 09:52:17 PM »
I rather thought the Little Axe is a very attractive model and your wing design is very clever.  Love to have the opportunity to fly one head-to-head against the Sky Sport.  Too bad the distance is so far.  Any chance of going to VSC?  It is worth the trip from anywhere!
Re: Sky Sport Mk II
« Reply #11 on: February 23, 2009, 10:11:00 PM »
Larry,, would love to see the re-configured plastic baggy tanks. Would you post a picture, i have messed around with them and i can't quite get it figured out..  or if they are for sale that would be great, i am sure there are lots of 1/2a flyers out there besides me that would like to find a great running tank, maybe something even better than balloons.
    • Minnesotamodeler
Re: Sky Sport Mk II
« Reply #12 on: February 24, 2009, 05:52:36 AM »
Hi Larry, I appreciate the compliment, especially from one so conversant in 1/2A...I agree completely, I'd like to see how the LittleAxe performs in comparison to others.  My problem in attending meets is distance, time and scheduling: Besides being in MN, far from most any gathering except Iowa's, events always center around the weekend--understandably--but, being a preacher, I'm sorta tied down here on weekends...set something up on, let's say, Monday, or Thursday, etc., and I'm there.
LIke the other Ray, I too would like to see details of your baggy tanks.  I use mostly floppy balloons these days, only drawback being they do deteriorate, have to be replaced about monthly.  I'm thinking your baggies are more durable than that.
--Ray
AMA902472
Re: Sky Sport Mk II
« Reply #13 on: February 24, 2009, 07:50:10 AM »
I would be happy to send a baggie to anyone who sends me a self-addressed, stamped envelope.  I have about 995 of them left in the box, and the box only cost $5.   ;D
I use 2" wide, 4" long 1mil bags.  Here are some photos of the box of bags, a modified bag, and the sealer I use.
« Last Edit: February 24, 2009, 08:26:59 AM by Larry Renger »
Offline Bryan Higgins
Re: Sky Sport Mk II
« Reply #14 on: February 24, 2009, 12:48:17 PM »
Larry
Nice looking Sky Sport.  I sure like how it looks, great paint job.... ;D
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Offline John Rist
Re: Sky Sport Mk II
« Reply #15 on: February 24, 2009, 10:23:13 PM »
Count me in for some.  Please Email or PM me your address.
Offline Roger Vizioli
  • CLiner
Re: Sky Sport Mk II
« Reply #16 on: February 25, 2009, 08:56:35 AM »
Larry,
Do you have a pic/description of how you seal the end of the bag?
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Re: Sky Sport Mk II
« Reply #17 on: February 25, 2009, 09:20:07 AM »
As with a balloon tank, described elsewhere, I cut a piece of fuel hose long enough to go to the back of the tank and extend just beyond the end.  I insert a piece of metal tubing (Aluminum or Brass, either one) about 1/2" into the end.  I then cut holes in the hose in a couple of places to insure that the fuel flow can not be choked off by the plastic covering just one opening.  Finally, I wrap the end of the bag over the hose and use copper wire to firmly bind it in place.  You need quite a bit of tension in the wire to assure freedom from leakage.  I gently pressure test the finished tank under water to insure that it has no leaks.  The wire compressing the fuel hose over the metal tube guarantees the seal.
  • CLiner
Re: Sky Sport Mk II
« Reply #18 on: February 25, 2009, 11:29:45 AM »
Larry,
Thanks, understand!
When I saw the "sealer" I thought you had a new way to seal around the fuel feed.   HB~>
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline John Rist
Re: Sky Sport Mk II
« Reply #19 on: February 25, 2009, 12:05:04 PM »
I went to the Uline web site and they have 2" x 4" 2 mil bags as well as 1mil bags.  Would the heaver bag be better?  I can see where the thiner bag would calapes better.  This is the first time I have heard of using vinyl bags as fuel tanks but it looks like the way to go.  By the way, how much fuel will it hold?
Re: Sky Sport Mk II
« Reply #20 on: February 25, 2009, 07:14:19 PM »
I can put about 25ccs in the tank in the compartment in the Sky Sport, probably around 30cc if the container was a bit larger.  You could go with larger bags, as they are so flexible and thin that the extra will just fill whatever space is available, but not take up significant room itself.  I would probably go with 3x6 bags and seal them down smaller as needed (if you have a sealer, flaunt it!).  Uline also has sealers, and you don't need the big one I have, it is one I got used, cheap.  Maybe e-Bay?  I haven't experimented, but you could probably do the job with a woodburning tool and a lamp dimmer.
I would love to figure out how to seal in a reverse curve to make a better end to wrap around the fuel hose!  The straight angle works, but the ideal would be an "S" curve.  (Think of the shape of an old hot-water bottle)
Offline John Castle
  • The Bent Pin
Re: Sky Sport Mk II
« Reply #21 on: February 26, 2009, 09:03:35 AM »
Interesting stuff. It occurs to me that if you have a Seal-a-Meal you could use the heat sealer built into it to seal the bags as well. Along those same lines even though it is a little heavy the bags used in the Seal-a-Meal are corrugated witch would help fuel flow when the bag is near empty..
John Castle
McMinnville, Oregon
AMA# 589650
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Re: Sky Sport Mk II
« Reply #22 on: February 26, 2009, 01:03:57 PM »
http://www.instructables.com/id/How-to-Make-a-Heat-Sealer/
You can make a heat sealer with stuff many of us have in our shop already.   I would guess that you could make the seal in any pattern you want.
Dave Siegler
NE9N extra class
AMA 720731
Offline John Rist
Re: Sky Sport Mk II
« Reply #23 on: February 26, 2009, 03:36:40 PM »
Larry is going to send me some of his modified bags (money is in the mail).  When they arrive I will take pictures and post them as I build my vinal baggy tank.
