CLICK HERE--><--CLICK HERE
Scarinzi Queen Build
Started by Dave Moritz, March 18, 2020, 10:45:22 AM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
Dave Moritz
Time for an update on this project. Am running into troubles getting a decent engine run with the little remote tank shown above. I tried mounting it closer to the engine, but to no good effect. The .020 starts well enough, but only runs in sputter mode with the needle quite open. Leaning it out, it barely breaks into 2-stroke mode before it quits from starvation.
I'm thinking that this motor just doesn't like a remote tank in the way I've mounted it. Or, the tank might be bad. Anyone here have any experience with these little motors?
Dave Mo...
" In a world of ready-made fiction, truth requires work."
D. Andersson
Dane Martin
Quote from: Dave Moritz on July 27, 2020, 09:03:57 PM
Dave Mo...
A couple things on that 020... those back plates are aged now (aren't we all)  and sometimes have needle issues. Also, the reed could be warped and not sealing. Have you taken it apart, cleaned it and performed the "suck test" to verify your reed is closing?
Dave Moritz
Thanks, Dane. Kind of a mystery. The motor runs well on the test stand.  I took a look inside the tank, and it's OK.
I might just have to find another .020 with a standard tank.
Dave Mo...
D. Andersson
Trostle
Dave Mo...
Might check that there is a good seal between the back plate and the crank case.  You explained that it runs fine on the test stand, but something might be changing that seal when it is mounted on the model.  You can check to see if there is a leak by placing several drops of fuel on the back plate/crankcase and turn the turn the crankshaft several times.  If there is a leak, bubbles will appear.  These things do not run if there is a leak.  Yes, they will start, but that is all.
944_Jim
Jump over to Cox International to pick up a custom backplate for the .020. There are YouTube videos and a write-up on CEF.
It looks like a mini product engine backplate. It will be complete, so it shows up, and you mount the kit!
Dave Moritz
Hmm, good suggestion, Keith. Will give that a try.
Jim: Yes, I see that a backplate is available and will give it a go if no luck otherwise.
What I'm hearing from both of you is that this thing should run on a remote tank setup.
Many thanks!
Dave Mo...
D. Andersson
Dane Martin
Quote from: Dave Moritz on July 29, 2020, 07:59:31 AM
Many thanks!
Dave Mo...
I have that same engine, and with a remote tank set up it runs great. You may just have a little hiccup somewhere. And by same engine, I mean with the tiny little product engine style back plate. I also have lots of tank type peewee engines. So this group of folks here can definitely get you running
Dave Moritz
Thanks, Dane.
This motor has a new crankcase gasket and new nylon reed. No leaks at the backplate and crankcase joint, so I did a tear down. The reed valve seems to work using the "suck and blow test" (sorry!). Nothing for comparison, but the intake seems to restricted. The reed seems too ride tight against the venturi opening and rotates very little. I'm suspicious of the circlip or the groove it sits in. The copper/berillium reed acts the same. Might have to take this problem over to the Cox forum. Either that, or Cox International gets a sudden, albeit small, shot of cash from south of their border.
Dave Mo...
D. Andersson
944_Jim
Mr. Dave,
Did you ever get to fly this one?
kenneth cook
                Dave, depending on year of manufacturing, the circlips were of a different thickness. I've found that the new overhaul kits that Cox International and Ex Models provide is the thicker circlip. If the reed isn't rotating under the circlip, it needs to.
                I flew my Queen Bee at Brodak's some time ago and Larry was present. He said it was "Cute". He signed the wing with his Lightning bolt and LS logo. I used 1/32" ply wing struts vs the wire the plans call for. Larry gave me a thumbs up, he really liked it and it really does fly well.
Dave Moritz
944 and Ken:
Nope, no flight yet. Never got a good engine run due (I thought) to fuel feed problems. Never considered the circlip potential problem. Might just have to pull it out of hiding and revisit. Pretty little critter it is.
Dave...
D. Andersson
Quality control on the PeeWee .020 was not perfect.  Even Cox didn't win them all.
My first "gas" engine was on my Little Stinker and it didn't have the power to get off the ground.  When replaced with a $3.95 PeeWee from a bubble pack it took off fine and had enough power to let me break the plane.
The engine then  went to a  "Little Gem" built from the plan in Model Airplane News.  Wow! From the plastic nasty to scratch-built in one giant step.  The Little Gem was a profile plane with a pretty good size diamond airfoil and it did stunt.
jfv
Here's my Queen Bee built last summer to celebrate Larry's achievements.  First flown at the NorthBeast Championships.  Flies great on 20 ft spectra.  1.5 oz ready to fly.  I built several when I was a kid.
Jim Vigani
944_Jim
#38
Both of these are quite attractive.
I'm seriously considering this for a backyard flier...barely.
I should say..."barely in the backyard" as the backyard has really limited flying area.
Edited for clarity...barely.
Jim Carter
 :)  Hello Dave!  Seeing your article cause my mind to drift and hear my box or left over wood call out ... "USE ME!  USE ME!"  To which I was unable to disobey!  Sir, this is your fault!  Although it is and has been a marvelous fault!
944_Jim
#40
Mr. Dave Mo,
I apologize if this has already been considered/checked.
I know the tanked engines will run fairly well with a failed O-ring between the backplate and tank. The o-ring will actually "seal" while the fuel level is above the "intake system."
Once the fuel level drops, extra air is drawn through the o-ring leaning the engine out to the point of "not running." Adding extra fuel to the mixture will fill micro-gaps and tears so the engine runs again.
The next time you have a chance, check that o-ring. Also check the pickup tube placement. The pickup should be in about the 7 or 8 o' clock position when viewed from the front of the engine (as long as you fly counter-clockwise).
I tend to check the pickup position and benchtest the engine with the engine clocked with the glowplug at about 10 or 11 o'clock (so the pickup is dead bottom for the test run) so the engine runs the tank empty.
It may be worth picking up a PeeWee overhaul kit from EXModel Engines or Cox International. If you prefer the 'Bay, both vendors have a 'Bay presence.
Anyway...back to my missives...
I'm thinking of minor visual changes to make my Queen Bee look more like a Pitts Lil Stinker. I won't change moments, nor sweep the top wing. The styling queues would be a canopy instead of an open cockpit, and a paint job that appears very much like the Stinker. I'll paint the area if the fuselage under the wing grey or blue just sonth3 red doesn't go all the way up to the wing.
Edited for clarity re: glowplug
Jeremy Chinn
I loved reading through this thread! Cute design, right up my alley. We have some snow coming in (shuts down the city), so I printed up the plan and dug out my box of .020's.
I picked one un-run Peewee and two nice TeeDees. I've also got a couple Perfect 1/4oz tanks I can pick from. I've run TeeDees for years on many designs, so I'm leaning that direction. I think doing so might also get me slightly longer lines.
Dave Moritz
Man alive did this come alive! Thanks for the compliments and my apologies to Larry for excessive modifications (not recommended) to his original plan.
I wonder if we might have a "happening" here. Six gents chimed in and possibly a seventh if the Divot (Dave Hull) is watching this thread.
On a whim, I picked up a Pee Wee (w/ integral tank) last week. Per 944's recommendation, I placed a rebuild order to EX. Will give it some bench time after incorporating suggestions by Ken and 944.
Dave Mo...
D. Andersson
Dave Moritz
PS to the above. My model of the Queen shown earlier in this thread turned out to be a hangar queen, albeit a nice one.
Dave Mo...
D. Andersson
944_Jim
Ken does mention something worth a double-tap. What you want out of the kit is the o-ring, the gasket, and the fuel pickup tube. It is in your best interest to retain the original reed and C-clip...especially the C-clip.
Be careful if you attempt to use the kit's tank screws. Check them against the old ones to be sure they aren't too long. This has been an intermittent issue for some of the .049 kits.
I'm checking my scrap heap now!
kenneth cook
              The Mylar reed which is the same shape as the original copper berylium works quite well not too mention is readily available. Once the circlip is in place, I like to rotate it in order to insure it's seated. When I'm satisfied with that, I take a X-acto and carefully nudge the reed underneath in rotation to verify it's not pinched. I then hook a syringe to the venturi and do the suck blow test. Don't just pull off the old hard pick up tubing from the backplate. The fuel nipple on the Pee Wee is very fragile and can break off. Use heat first and this will make the tubing flexible and it will slip right off. Wiggling the old one prior to what I mentioned will immediately snap the barb off.
One important thing I like to verify is the area where the venturi of the tank plugs into the backplate. Inside this area, there's a small hole. This is where the point of the needle is located. Remove the needle and insert a fine piece of wire down through the spraybar and insure it exits the hole I mention. Repeatedly do this as build of crud isn't uncommon here and alcohol can help break up the crap in there. Prior to reinstalling the fuel pickup tubing, insert a modeling pin back through the fuel barb with the needle removed and insure that you can see the pin through the spraybar hole looking down into it.
When doing the suck blow test,  a drop of oil is sometimes needed on the reed which will assist the reed in sealing. If I find it's leaking in anyway, I always flip it over before I try anything else. When the Pee Wee is back together, I pressurize the tank to insure no leaks as well. If air is immediately escaping, check the screws on the backplate, listen at the venturi intake as that is a immediate sign the venturi o-ring isn't sealed. Place a drop of oil on the threads at the top of the backplate where the needle is inserted, this can yield air leaks where the spraybar is pressed into the backplate and also threads themselves. Keep in mind that other leaks can also show their ugliness such as tank to crankcase, screws through the backplate and tank to backplate connection. While some of these might have a moderate impact on engine run, all of them at some point matter and should be resolved.
944_Jim
Is this thread about to become a group build topic? I have enough bits and scrap to start mine. It will be slow going as I'm also trying to clean out the hobby closet.
Jeremy Chinn
#47
I'll play Jim. I started cutting this morning.
I used my removable gluestick method with an extra printed set of plans. Makes quick work of cutting the parts.
I'm making 3 small changes.
Teedee power
Remote tank
Small bell crank move Still need to cut some parts for that.
Jeremy Chinn
Needs wing struts, tank mount, pushrod and finishing.
Weighs 44 grams/ 1.5ozs at this point.
944_Jim
I haven't even had a chance to make templates. Dude, you fly through this stuff!
What are your plans for a tank?
