  • July 17, 2025, 07:16:13 PM
Author Topic: Safety alert: See my post in the rules section on Spectra lines  (Read 2009 times)
Offline Larry Renger
I have had very bad results with the AMA recommended Spectra line ends.  After some experimentation, I have a solution that works MUCH better.  Look in the rules section for the info!
Re: Safety alert: See my post in the rules section on Spectra lines
« Reply #1 on: July 16, 2011, 10:17:20 AM »
Bumping this up for Jason.  Maybe needs to be locked at the top of this section. H^^
Offline jason_sogolow
« Reply #2 on: July 16, 2011, 09:13:59 PM »
Uhm... I'm not finding this post, where is it?
Jason
Burbank, CA - AMA 965084 & Valley Circle Burners!
« Reply #3 on: July 24, 2011, 10:06:19 PM »
Oddly enough, in the rules section.  Do a search on Spectra if all else fails.  R%%%%
Offline Phil Krankowski
« Reply #4 on: October 09, 2012, 10:17:41 AM »
If this is such a big safety deal, can it be placed in an area that everybody can see?
Phil
Offline John G. Park
  • "Is This a Day or What !?"
« Reply #5 on: October 19, 2012, 06:35:29 PM »
I looked through the Rules for Prec Aerobatics but didn't find anything.
Aslo did not find a way at AMA to search for Spectra.
Can oyu supply more like the name of the bad knkots and what might be better or a clearer reference point to locate the article
Offline don Burke
« Reply #6 on: October 19, 2012, 07:17:35 PM »
Spectra Lines specs are in AMA Control Line General rules  sect "5.3.5.1 Spectra Lines.."
don Burke AMA 843
Menifee, CA
  • Gravitywell
« Reply #7 on: October 19, 2012, 11:04:59 PM »
Thats a huge help to everyone thats not a member of AMA.  Thanks. HB~>
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline BillLee
« Reply #8 on: October 20, 2012, 03:31:53 AM »
What does AMA membership have anything to do with accessing their rules on their website?
Bill Lee
AMA 20018
« Reply #9 on: October 21, 2012, 06:40:47 PM »
Probably because an assumption was made that this information exists on THIS website.
Yes, All the AMA literature is available on the AMA website, and no login is needed.  Knowing that it is in the rulebook is very helpful.  Knowing the section will make it easy to find.  Thank you.
Phil
« Reply #10 on: October 21, 2012, 06:55:51 PM »
To sum up this is the only knot allowed
a double five turn uniknot
Lines shall be sized by weight and engine size using the larger lines indicated.
http://www.modelaircraft.org/
If I got anything wrong, PLEASE correct me.
Phil
