  • August 04, 2025, 11:25:38 PM
Author Topic: ringmaster 207 flys in the ringathon  (Read 2033 times)
Offline Joey Mathison 9806
« on: October 09, 2010, 04:55:22 PM »
put in 4 flights with her she has norvel .061 for power and i am running it on pressure.
200 mph man ama#9806 joey mathison
Offline ray copeland
Re: ringmaster 207 flys in the ringathon
« Reply #1 on: October 09, 2010, 08:38:19 PM »
Joey, very cool!! I presume you are talking crankcase pressure, if that is right i would love to know your set up and starting procedure.  I have always had problems using crankcase pressure on these small engines. Looks good!,   Ray
« Reply #2 on: October 09, 2010, 09:32:03 PM »
yes it is crankcase pressure i use the factory taped backplate. i am useing the nelson style head with the merlin  glow plug and 2 head shims  5 1/4 x 4 prop. use starter for starting no choke peak the rpm then back off two clicks.tank is a standard vented tank with the fill pluged and the overflow gets the pressure line.
« Reply #3 on: October 11, 2010, 01:12:08 AM »
Hi Joey,
When Pat first drew the 207 up for me, it had flaps identical to the 576 but for a .061. ;D  Did you alter it or has he changed the plans?
Mongo
« Reply #4 on: October 11, 2010, 04:52:19 AM »
Bill you will have to ask my Dad he built this great flying 207. it does fly great.
Offline Roger Vizioli
  • CLiner
« Reply #5 on: October 11, 2010, 06:44:34 PM »
Hi Joey,
Mongo
Hi Bill,
Pat added a note to the RM 207 plans saying: "Flap Options - The flaps maybe connected as shown, or glued on fixed".
I built mine fixed, no regrets, flies great!
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline jim gilmore
« Reply #6 on: October 13, 2010, 07:10:44 PM »
Was this 207 built from plans or a kit ?
