  • August 01, 2025, 08:23:08 PM
Author Topic: Ray's Rumbler  (Read 2171 times)
Offline ray copeland
Ray's Rumbler
« on: April 04, 2008, 10:04:19 PM »
Rumbler kit from Minnesota Modeler. Great kit, perfectly fitted pieces and easy assembly. Sporting a Norvel .061 ame with in-wing bladder and weighing in at a hefty 5.8 oz. w/o fuel. Can't wait to get this one on a set of 42 foot lines!!   >:D
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Ray's Rumbler
« Reply #1 on: April 05, 2008, 06:46:45 AM »
Say Ray, looks pretty good...get ready for a handful!
You'll have a blast.
--Ray
--Ray
AMA902472
Re: Ray's Rumbler
« Reply #2 on: April 05, 2008, 07:15:52 AM »
Ray, that looks like it would truely be a blast to fly.  Hope it flies as well as it looks.  DOC Holliday
Offline Bill Adair
  • AMA 182626
Re: Ray's Rumbler
« Reply #3 on: April 05, 2008, 12:49:06 PM »
Hi Ray,
Looks really good!
Noticed the fuel pinch off. Are you running pressure, or a balloon tank?
Re: Ray's Rumbler
« Reply #4 on: April 05, 2008, 03:31:54 PM »
Hi Bill, this one is pressure, ame's mostly require either muffler pressure or a bladder. Have never tried crankcase pressure.  I actually have run a couple of ame's on balloons with a successful 4-2-4 , not really trying to ,  guess i just had the needle set just right, it was pretty impressive with these little motors on 30 foot lines like i fly in the backyard. In my opinion for stunt flying 1/2a's, balloons don't get the credit or the research and refinement they should. If the engine you are using does not require pressure i would much rather use a balloon than any hard tank i have tried. I am still researching this theory but right now it is 2 to 1 in favor of balloons. Still trying to find the right set up for the holding tank for up to 1 oz. Would love to find a way to use a thick baggie to hold the balloon on the plane instead of a plastic bottle. Still looking, that's what makes this a never ending search!, and fun!
    • Minnesotamodeler
Re: Ray's Rumbler
« Reply #5 on: April 05, 2008, 09:49:57 PM »
That Rumbler is one mean flying machine...you better not try it on 30' lines!  42' recommended.
--Ray
AMA902472
Offline Bill Adair
  • AMA 182626
Re: Ray's Rumbler
« Reply #6 on: April 05, 2008, 11:57:01 PM »
Ray,
Thanks for the info.
Jim Walker came up with a brilliant idea for a balloon tank holder, over fifty years ago!
His RTF Firebaby used a simple molded canopy, that snapped onto the balsa fuselage right behind the engine mount. The hollow canopy held the balloon tank, with a small hole in the front of the canopy for the fuel line to exit. I don't remember what kind of engine runs I got with that set up, but it must have worked pretty well, as many of us have very fond memories of flying the Firebaby successfully!
The tank was a bit higher than most would like on a modern stunter, but the Firebaby flew mostly upright anyway, with that undercambered wing.
Offline Larry Renger
Re: Ray's Rumbler
« Reply #7 on: April 15, 2008, 09:22:07 AM »
For holding the balloon, check out my Sky Sport model.  Those cheek cowls are really a tank holding box! ;D
The model was published in Flying Models July 2007 and is now an RSM kit, so you can look at it on Eric's website: www.rsmdistribution.com
    • Minnesotamodeler
Re: Ray's Rumbler
« Reply #8 on: April 15, 2008, 04:30:41 PM »
Clever.  Looks good too.
--Ray
AMA902472
Re: Ray's Rumbler
« Reply #9 on: April 18, 2008, 09:37:39 AM »
So far, it has racked up 3 trophies in 1cc competition and a first place in Advanced Profile at the Southwick Memorial contest in Phoenix.  A highly competitive design!  (Modesty is only one of my MANY virtues)   VD~
