  • July 07, 2025, 05:01:03 AM
Author Topic: Props & Engines  (Read 1893 times)
Offline Chuck Schultz
Props & Engines
« on: November 06, 2015, 07:42:21 AM »
How can you tell a left hand prop from a right hand prop and why the difference? Also are there right hand engines vs. left hand engines. If so what would happen if you put a Right hand prop on a Left hand engine? HB~>
Offline Larry Renger
Re: Props & Engines
« Reply #1 on: November 06, 2015, 08:57:45 AM »
Right hand props produce thrust running counter-clockwise as seen from the front of the model.
Cox reed engines will run either direction. Norvel, Tee Dee, Medallion, AP Wasp engines only run counter-clockwise.
A Left hand prop on a right hand engine is useful in a pusher configuration.
Offline bob whitney
Re: Props & Engines
« Reply #2 on: November 06, 2015, 03:14:52 PM »
 cox, K&B and i think Fox used to make left handed cranks so u could run in the other direction ,mostly for Carrier and 1/2a speed  ( cox )
rad racer
