  • July 09, 2025, 01:39:18 AM
Author Topic: Picco .05 anyone using them?  (Read 9699 times)
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« on: February 23, 2014, 01:56:46 PM »
I bought a few of the Picco 0.05 car engines when they were cheap, should have bought 10.....   The intent was to convert them myself to areo.  Then I heard about the weak crank, and the project stalled.
apparently Doug G has a fix for it!
http://www.the-printer.net/DookCat.html
They are very fast and easy to handle.  Hoping to use them for 1/2 combat.
so for like $80 per engine I can have a world beater.
Is anyone here running that engine?
Dave Siegler
NE9N extra class
AMA 720731
Offline kenneth cook
Re: Picco .05 anyone using them?
« Reply #1 on: February 24, 2014, 03:48:47 PM »
           I know a few in New Jersey that were using them for 1/2A combat. I have a few myself that are scheduled to go to Doug. I was impressed. They were showing more rpm's than the Cyclon. Ken
Offline Patrick Hempel
  • Genes Jet
    • DMAA web site
« Reply #2 on: March 03, 2014, 05:12:30 PM »
Hi,
I have four, Doug setup, running them in 1/2 a proto.
They are very popular in this event. I run crankcase pressure. tacking around 32,000 to 34,000 rpm
Been running them for three years now, I have broke one shaft, but Doug did me right on the fix.
use caution when using the starters, the best speed I got was 86 mph. hoping to make it to 90 someday  S?P
Very nice motors.
See attached picture.
Patrick
Patrick Hempel
Offline Bill Adair
  • AMA 182626
« Reply #3 on: March 03, 2014, 11:52:17 PM »
Hi Pat,
Some time back I purchased a couple of the Picco P-Zero engines when they were on sale, and was wondering how well they stood up after Doug's rework. Your reply here has rekindled my interest in this project by answering one of my main question i.e. durability of the reworked engines, and I thank you for that.
A friend of mine is very interested in half-A Proto speed, so I thought here was a way to participate in the event as a supporter, since my piloting skills are kind of pathetic.  ;D
So I bought the engines, and talked to Doug G. about the rework, but hearing no further word on the performance of these beautiful engines I kind of hesitated to persue this any farther.
I'm also a great fan of sport FF as that is where I started in this hobby many years ago, and these Picco engines are very competitive in that event from what I hear. Now that R/C assist is so inexpensive, there is also a chance for someone like me who can no longer chase wayword airplanes on foot.
I'd like to hear more about your experience with Proto Speed, as we have a good group here in NW Oregon that is trying to promote the event.
Offline Jim Rhoades
« Reply #4 on: April 24, 2014, 02:54:19 PM »
     I talked with Jerry Rocha last Sunday eve, 4/20, and he told me that he had just upped his 1/2A Profile Proto record from 108.78 mph to 111.68 mph.  Not too sure on the decimal but it's close to that.  His old record was with a CS .049 but the new record is with a de-stroked Picco P zero.  He says a new prop is the secret to the fast time.  All of Jerry's engines are fast and his Picco's are no exception.  He says he turns 34,000 to 36,000 on the ground with his flying props.  His latest proto is very light and accelerates like shot out of a cannon but quits flying quickly due to the draggy profile with landing gear and exposed controls.
     I flew the model a couple flights last year at the NW Regionals and gave a little up on takeoff per Jerry's suggestion and the resulting wingover put me behind it far enough that I had to get out of the pylon.  The flight probably would have set the record then if not aborted.  Jerry said he doesn't know why he told me to give a little up.  The next flight started out well with a nice flat takeoff and smooth pylon entry only to have the tank fly off at about lap 3 or 4.  I hope to get a new Picco powered proto done soon to see if I can give him some competition.
Jim Rhoades
  • sport flier
« Reply #5 on: April 24, 2014, 07:38:58 PM »
I just sent 2 engines to Doug.  A little excited about it.  Hope the crank mode will make it work for my use.
Dave Siegler
NE9N extra class
AMA 720731
Online Steve Helmick
« Reply #6 on: April 24, 2014, 09:22:47 PM »
Ken Burdick was one of the early promoters of the engine, and quickly found it was not a legal .049. His went off to Doug Galbreath for revisions, and DG did a lot of stuff to the crank. OBTW, Doug turned 80 recently.  (051) Steve
  • sport flier
« Reply #7 on: April 30, 2014, 08:22:19 PM »
just got the little monsters back.  6 day turn around including shipping.
Now have to figure out prop, fuel and plug.  Note Not using them for speed so they are not destroked.
Dave Siegler
NE9N extra class
AMA 720731
Offline Bill Adair
  • AMA 182626
« Reply #8 on: April 30, 2014, 08:33:23 PM »
Dave,
Can you post pictures of your Picco engines?
I considered similar mods for mine for sport flying only.
  • sport flier
« Reply #9 on: May 01, 2014, 04:10:34 AM »
I was going to do it myself, but learning of the crank breakage and fixes, I just had Doug do it.  It is his needle , venturi and prop drive and spinner.   I had him just turn down the stock head and I'll use turbo plugs.  On the crank he did the sleeve and the new bearings but did not regrind the crank pin, so it is a .05.  The goal is to use them for combat, and sport flying.
Dave Siegler
NE9N extra class
AMA 720731
  • sport flier
« Reply #10 on: May 12, 2014, 09:30:36 PM »
Just ran one tonight.  It was over propped a little, but on a bladder it was a very easy system to work out.  Used a OS P5 turbo plug and sig 25% fuel.  3 short runs on a bladder.  Starts easily handles like a much larger engine on pressure.  The needle valve that Doug makes is the best one I have ever used.  Now to get some hot fuel, and work with props.
Any suggestions on where to start on props?  APC 4.6 x 3?
Dave Siegler
NE9N extra class
AMA 720731
ChrisSarnowski
« Reply #11 on: May 20, 2014, 11:43:30 AM »
Aren't those engines 0.85cc ? The displacement (0.05187 cubic inch) is a little too large to meet AMA rules for combat (0.0514 cubic inch).
I guess it depends on local rules, there are some places that allow 0.061 plain bearing.
-Chris
  • sport flier
« Reply #12 on: May 23, 2014, 04:06:13 PM »
.85 cc == .051 to 2 sig figures.
I maintain that the engine is legal ( for combat) and someone has to prove it otherwise.
Local rules?  In most cases if you show up, they will let you fly.  Don't worry.  I wont win anyway.  Only the guys with the impossible to get foras can fly?
« Last Edit: May 24, 2014, 05:32:26 AM by dave siegler »
Dave Siegler
NE9N extra class
AMA 720731
ChrisSarnowski
« Reply #13 on: June 16, 2014, 06:35:22 AM »
Dave,
I would say the burden is on you to prove it is legal, since the published specifications say otherwise.
Last time I looked for specifications on the p-zero, the bore was specified as 10.5mm and stroke as 0.98mm.
You can do your own math but that comes out that comes out a little shy of 0.85cc. (0.8486cc to 4 places).
Convert that to english units and you get 0.05178ci.
The AMA half-A combat rules clearly specify maximum displacement as 0.0514 cubic inch.
In a local contest, certainly I would let a person fly the Picco if everyone agreed. Which they would.
Taking the Picco to the Nats might be a different story.
Besides, 0.8cc Fora engines are not impossible to get. Just pricey.
-Chris
« Reply #14 on: June 17, 2014, 03:27:29 PM »
According to the link, Doug gets $215 for the finished unit.  1/2A is .050 maximum.  That's why they made .049's.  The .051 was a somewhat shaky accomidation to the TeeDee .051 which was a purpose-built cheater engine to enable free flighters to use 1/2A airframes in 1/2A free flight.  If Cox went to the trouble of making oversize pistons to make the TeeDee .049 into Class A engine, it's a Class A engine.
If somebody took the trouble to downsize a Picco .085 into an .049 he should have aimed for .047 or .048 and made legal 1/2A's.
What is the purpose of 1/2A?  A low cost event or another opportunity to buy the event with over-priced almost impossible to get equipment?
Offline Joey Mathison 9806
« Reply #15 on: June 17, 2014, 09:29:29 PM »
 p-0 holds the proto record now and we all know if you pop a record you are going to open her up for inspection..
200 mph man ama#9806 joey mathison
ChrisSarnowski
« Reply #16 on: June 18, 2014, 05:56:14 AM »
That is a good point, Paul. It was probably the Cyclon 0.8cc engine that started the trouble. Then Fora and Profi followed on.
The Picco engine cost is artificially low since it is a discontinued engine. I believe it was just as pricey as the fancy engines when it was an active product.
It is a good option for 1/2A fun in the right places, I meant only to point out there is a size issue if you are going to compete more seriously.
-Chris
« Reply #17 on: June 18, 2014, 07:19:45 AM »
1/2 A combat started out as an affordable event with $6 Black Widows and $8 TeeDee .049's.
Now you need a $215 Picco that has more power than an LA15.
So just make a combat event with LA15's and give 1/2A the last rites.   Anybody can get a new LA15 for $80 or an Ebay unit for a lot less.  Then maybe there would be enough flyers to have a contest.  As it stands now, you can get into F2D with less effort than 1/2A.
For the last three days I've been combing the new for a matched pair of 1/2A's for a twin engine scale job.  There's not much out there.  Even with .061's the well is dry.  I can use old TeeDee's.  Just buy six and hope three will run.
Jim Roselle
« Reply #18 on: June 18, 2014, 09:03:25 AM »
If you modify your cox engines to run on bladder pressure you'll find them to be easy starting and extremely reliable.
Jim
Offline Mike Callas
« Reply #19 on: June 18, 2014, 11:06:31 PM »
Texastimers has the bladder material and bits Including a fine pitch needle valve for a TD
Offline Andrew Tinsley
« Reply #20 on: June 19, 2014, 10:57:05 AM »
Hi Paul,
There are a lot of TD 0.049s out there, new in box. They don't cost a huge amount either. I have just got one in the mail today. I do agree they can be a pain in the neck to run in a conventional manner. I did try bladder pressure but managed to get covered in high nitro fuel when the bladder went whoosh! Maybe I am misunderstanding what bladder pressure means? If so can someone spell it out in simple terms?!!!!
One thing I don't understand is that if the bladder is pressurised by pumping in fuel. then surely that pressure will be changing continuously until it drops to zero?
  Sorry if I have hijacked the thread, maybe I should have started a new one.
Andrew.
BMFA Number 64862
  • sport flier
« Reply #21 on: June 19, 2014, 10:21:51 PM »
Paul,
I have $75 rework in each engine.  The engine has a weak crank.  Otherwise I would have only $35 per engine, and a couple hours of my own (free) lathe work.
The was the goal, a cheap combat PRACTICE engine, but due to weak crank I missed. The engines were only $20 each. he sells a read to run engine for $215.
Another $30 per engine will destroke them to get them .049 legal but who cares?
Chris,
As far as legal... splitting hairs?  You only have 3 digits, the fourth is not significant go back to your high school chemistry class, you don't have 4 digits.
Also when I measured the stroke with a dial indicator, I got less than the quoted 10.5mm but I mat be out of cal.
The engine is larger than a td 051 at .0517, but this combat, not speed that little makes gives no advantage.
Good for you you just stopped someone else from competing!   The contests are just full of 1/2A combat the are just turning away everyone!
When you are there alone flying matches alone, pat yourself on the back....  At my skill level, the mild fuel I use and the cheap inefficient cox props, the .0003 won't matter.
Any contest around here except the nats allow plane bearing 061's anyway.
The engine runs great, it handles like a much larger motor. It's been fun
Dave Siegler
NE9N extra class
AMA 720731
ChrisSarnowski
« Reply #22 on: June 20, 2014, 06:20:13 AM »
Dave,
I am just pointing out the rules for AMA half-A combat. I did not write the rules for the displacement of the engine nor did I change the rules to bump the size slightly to allow the TD 051 to compete. We both agree that local contests will let you use the Picco. It is even possible that you could get the rules changed or a waiver of some sort to use it at the Nats. If I was at the contest, I would lend you one of my engines to compete if they said no.
Maybe it is even a good idea to allow plain bearing 061's at the Nats to encourage entries.
-Chris
Offline Fredvon4
  • Central Texas
« Reply #23 on: August 21, 2014, 09:33:59 AM »
I have a couple of Doug Galbreath Picco P-0 early conversions that have the weak crank shaft. At the time he was selling two versions....one was for the FF crowd and was de-stroked to meet the rules...those of us who got the combat versions were not de-stroked. He now produces them with a redesigned crankshaft and all are de-stroked and stronger
Of course all speculation can be solved by calling Doug... I know many of you all know him personally
Fred von Gortler IV
