  • August 01, 2025, 08:21:55 PM
Author Topic: Not stunt, but 1/2A! Zippie hollow log racer  (Read 6566 times)
Offline Larry Renger
« on: November 08, 2011, 11:03:46 PM »
We have a "Hollow Log" drag race coming up in December.  Basically 10 laps from a standing start, Cox reed engines only.  Minimum area 54 sq.in. and all components must have started from solid blocks and sheets.  Front cross-section minimum - same as Babe Bee backplate.
I am building my own design, the Zippie.  So far the basic airframe is 1 ounce.  Still needs landing gear,bellcrank, leadouts, etc.  It should come in at under 4 ounces.
I have a Cox Venom to put in it.  VD~
Offline BrianW517
Re: Not stunt, but 1/2A! Zippie hollow log racer
« Reply #1 on: November 13, 2011, 12:06:42 AM »
  H^^  D>K Go lite on dope & it should be fast!  :o  <= n~ H^^
« Reply #2 on: November 13, 2011, 08:48:08 PM »
Actually, since I intend to use 50% Nitro, Epoxy finish is in the cards.  :X
Offline don Burke
« Reply #3 on: November 14, 2011, 11:09:33 AM »
Why worry about longevity?  It's just a one day thing, and by next year you'll probably have a different (better) idea of how to do it.
don Burke AMA 843
Menifee, CA
« Reply #4 on: November 14, 2011, 12:07:16 PM »
When I take this much trouble to design and build a model, I want it hanging around looking good.  It can function as a show model in our AMA Expo booth for years to come.  n1
Next year we will have a one design race using Dale Kirn's Torquey biplane design.  I don't know what the engine limitations will be yet, but I have a Cyclon, a Stehls and a VA in addition to some pretty darn good TDs.   ;D
« Reply #5 on: November 15, 2011, 10:11:52 AM »
It's coming along!  I need to do the landing gear struts and cowl, but it could be flown after one coat of epoxy if I run out of time.
Offline Mark Misegadis
« Reply #6 on: November 15, 2011, 01:42:19 PM »
It looks Sporty!  Are you going to form up a cowl out of an aluminum can or build it from Balsa?
Mark
« Reply #7 on: November 15, 2011, 06:04:59 PM »
I have already made a form to mold a fiberglas cowl.  I will use epoxy and the balloon method.  Probably 2 layers of 1ounce cloth, one straight, the other at 45 degrees.  I also have Kevlar and carbon veil materials.
The form is blue foam with a 1/32 ply front ring that will be bonded to the cowl.  At the back is a 1/8" ply match to the firewall to assure a good fit.  I ironed SLC covering onto the foam and will coat that with PVA release.
Lay on the 'glass, and then push an inflated balloon down over the whole thing to apply pressure and form a smooth outer surface.  The pressure will squeeze out any excess epoxy.  I have done lots of 'glass vacuum bagging, but not this particular technique.  Wish me luck!  ~^
« Reply #8 on: November 16, 2011, 09:50:33 AM »
I am sure you will do fine Larry. I cannot wait to see the results~!!!
Mark
« Reply #9 on: November 16, 2011, 10:04:12 AM »
BTW the whole build and plans will be in a several part series in the Half A Flyer magazine, so sign up, Yall!  n1
Offline rustler
« Reply #10 on: November 16, 2011, 01:44:01 PM »
I think this is the first time I've looked at the 1/2A section. Looks nice Larry, reminds me of a real plane but I can't think what. May be some sort of Lockheed?
Ian Russell.
« Reply #11 on: November 16, 2011, 02:26:27 PM »
What were that Spitfire and Hughes H1 racer DOING in that hangar last year?   VD~
« Last Edit: November 17, 2011, 10:15:52 AM by Larry Renger »
Offline bob werle
« Reply #12 on: November 17, 2011, 11:00:39 AM »
Larry--Next year no engine restrictions  anything up to 1cc
Bob
ama 5871
« Reply #13 on: November 17, 2011, 10:27:48 PM »
Bwhaaaaahaaahaaa!   VD~  :X  DV^^
« Reply #14 on: November 18, 2011, 07:20:35 PM »
Here come the custom built engines.   And they wonder what killed 1/2A Mouse One. VD~
« Reply #15 on: November 18, 2011, 10:34:22 PM »
The upcoming race is for unlimited engines, and does not apply to Mouse at all.  ;D
An upcoming article in the Half A Flyer will be how to build a competitive reed engine.  In addition, the Venom, which was mass produced by Cox, was superior to home modified engines because we (Cox) could do things the home builder could not!  Paul Gieabault could confirm that he held record with a Production Venom engine. We worked together to develop it, but was then produced in quantity. I am not aware that further fitting or modifications were used, and I think he still has and uses the stock engine.  Perhaps he will respond here.
I intend to show how to build your very own version. Subscribe and stay tuned!  mw~
Offline PaulGibeault
« Reply #16 on: November 24, 2011, 04:53:27 AM »
HI Guys,
Yes indeed, the Cox Venom was the fastest Cox engine. It had better cylinder porting, a lightened piston, a better balanced crank + the nylon reed retainer (although not faster) was more reliable. The ONLY modification I do is to replace the original piston with that from a TeeDee. And then ONLY IF the original piston has failed. The (still current) record holding engine was indeed stock including the glow plug. I dis-assembled it right at the Nats to prove it...
The major dissappointment with the Venom was it's fragile piston. Sadly, if they had just made it per Larry's direction, it never would have failed. My original Venom prototype (from Larry) is still going strong with all original parts. I keep it as a 'reference engine' & mostly just bench run it. It's always packed in my mouse kit as an emergency #4 back-up engine. (Any AMA NATS is considered an emergency...!)
I'm green with envy not being able to enter the 'hollow log' event!
Offline kenneth cook
« Reply #17 on: November 24, 2011, 08:01:24 AM »
              Larry, the plane as it is shown in the picture with the carbon veil applied is 1oz. sitting as is? I've been building some combat wings which I though were fairly light. I can't seem to bring them under 3 oz's. I'm using arrowshafts and fiberglass composite tubes for my fuse. My lightest with all the weight stripping I can do is 3 oz on the money. I guess I have to keep trying. I've been using a lot of white glue thinned down but I don't want to sacrifice strength either. Ken
« Reply #18 on: November 24, 2011, 09:24:21 AM »
Well, I used a block of balsa for the fuselage that I had to scrape off the ceiling, and the wing wood was about that light too.  I have been collecting good balsa for at least 40 years, and it just gets lighter with age.  Also, this model is TINY!  54 sq.in. with a minimal cross-section fuselage hollowed out.   y1
I just finished sending the first "episode" in the ongoing saga of construction to "Half A Flyer.  Plans are included.
Paul Quote: I'm green with envy not being able to enter the 'hollow log' event!
So build one and we can easily find a proxy flyer for you!  They do that in the multi-engine profile scale contest in Tucson and most of the Musciano events.  :!
« Last Edit: November 25, 2011, 08:53:31 AM by Larry Renger »
« Reply #19 on: December 03, 2011, 07:26:59 PM »
I had to add tail weight, and the cowl and spinner and wheel pants are not done.  But tomorrow is the race.  HB~>
It has two coats of Klasskote epoxy on it, so after the race I can clean it with anything I need to and do the final finish.  Plus, even the hi Nitro fuel shouldn't touch it.
Current weight is 4.3 ounces.  When finally complete, I suspect I'll need even more tailweight, and it will push 5 ounces.  I should have cut the nose 1/2" shorter.  Oh, well.....  Then again, after the race I have time to do it right!
Offline AT1984
« Reply #20 on: May 04, 2012, 10:56:53 AM »
Larry,
Do you have any pics of the finished plane?
Thanks!
« Reply #21 on: May 04, 2012, 06:14:41 PM »
No, because it isn't finished.   HB~>  I still need to mold the cowl, and then apply the deco.  It did win, however.  I made up a pseudo Venom with a small tank, as the normal one 'bout killed me!  Laps under 2 seconds for about a minute had me staggering.
The next race is at the Toys for Tots in December, so it needs to be done then.  We are going to longer lines and providing (much milder) fuel.  65% Nitro plus Propylene Oxide was a bit much with that itty bitty APC 4" prop.  I'll wager that reedie was singing a 30K note.
Offline AT1984
« Reply #22 on: May 04, 2012, 09:52:15 PM »
2 second laps? I'm dizzy just thinking about it. I'd like to build something like it, someday...(if there were ever any plans for it, hint,hint)
Thanks!
« Reply #23 on: May 04, 2012, 11:15:52 PM »
Talk to Larry Rice, he has the plan and article for Half A Flyer.  y1
« Reply #24 on: October 23, 2018, 03:48:00 PM »
Since Blackhawk Models and 1/2 A Flyer are. Gone, if there is interest the plans can be posted here.
Offline Dane Martin
  • heli pilot BHOR
« Reply #25 on: October 23, 2018, 04:26:10 PM »
Interested!
Offline curtis williams
« Reply #26 on: October 23, 2018, 06:32:12 PM »
Good idea!
Offline RK
« Reply #27 on: October 27, 2018, 09:01:41 AM »
I've been interested in 1/2 A flying since I learned as a kid in the early 50's. I lived in Southern Cal. not too far from the Cox Factory and a whole gang of kids learned to fly on the PT-19!!
Now I can't fly anymore But I still love to build all types but especially 1/2A, on my bench now is a !/2 A Twin engine with OK Cub 049 Engines and a Hollow Log plane I am going to call "Fuzzy" trying to keep up with Larry & Dane!
Going back to the bench, RK Flyer
If you come to a fork in the road,,,,Take it!
Offline 944_Jim
« Reply #28 on: October 27, 2018, 05:36:34 PM »
Twin? Twin? Did I hear something about a twin?
I love twins!
Pics please.
TIA
Offline RK
« Reply #29 on: October 28, 2018, 01:54:16 AM »
Jim......I am still working on it and I don't know how to post pictures .But the plans are on the Outer Zone. Its called the "Half A Twin" by Hal De Bolt 1951. Its a nice one!!
RK F lyer
Offline 944_Jim
« Reply #30 on: October 28, 2018, 09:47:05 PM »
RK,
I know the one...Grumman angle-rudder, dual tail, cockpit "nose" ends behind the wing trailing edge, if I have the right plane. This is one I'd like to see completed.
Please do post once you figure out how. Posting here is pretty easy once you learn how to resize for the file-size limit.
Offline Dane Martin
  • heli pilot BHOR
« Reply #31 on: October 28, 2018, 10:10:21 PM »
You can email the pics to me and I'll resize them. Or if they're on your phone, sometimes you can text them to yourself and save again. It'll save, resized in a different folder.
« Reply #32 on: November 20, 2018, 07:22:19 PM »
I hav posted photos and plans on a separate thread. If needed there are detailed construction photos that are ready to post
Offline 944_Jim
« Reply #33 on: November 20, 2018, 07:48:31 PM »
Hi Mr. Larry,
Please post the link to your thread. This is one plane I'd like to see.
Oh, BTW...I love my RSM 1/2A Renger handle!
I know, I know...we are threadjacking RKs post. Sorry RK!
« Reply #34 on: November 20, 2018, 09:41:05 PM »
Search for Zippiee and you shall be rewarded!
Offline Dane Martin
  • heli pilot BHOR
« Reply #35 on: November 22, 2018, 05:31:24 PM »
Hi Mr. Larry,
Jim, the pdf download is right directly above the picture.
https://stunthanger.com/smf/12-a-building/zippiee-racer-information/
Offline bob whitney
« Reply #36 on: November 22, 2018, 07:43:09 PM »
thought the rules said 56 aq in wing
rad racer
