  • June 16, 2025, 03:16:48 AM
Author Topic: Wanted: Needle for Allyn .049 Outboard  (Read 841 times)
Offline pat king
    • PDK LLC
« on: May 26, 2013, 08:53:52 AM »
This probably does not belong here. I need a needle for an Allyn Sea Fury .049 Outboard. I bought one with the needle broken off in the spray bar. The needle is seated in the spray bar, I do not know how much problem it will be to remove the stub.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
