  • July 30, 2025, 01:21:44 PM
Author Topic: Norvell .061  (Read 2696 times)
Offline Allan Perret
  • Proverbs
Norvell .061
« on: September 30, 2010, 02:27:57 PM »
Anybody know what the thread size is on the prop screw ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Norvell .061
« Reply #1 on: September 30, 2010, 03:46:01 PM »
Do you have a ruler?  My Big Mig 049 is 3mm.  It's pretty easy to tell -- it'll be metric, probably 3mm like my 049.
Standard metric sizes are M3x0.5, M3.5x0.6, and M4x0.7.  Unless those Ruskies are up to tricks, it'll be one of those.  Diameter is obvious if you have calipers and can be squinted out if you have a ruler (3mm is just a hair less than 1/8).  You can figure the thread pitch by counting off ten or twenty threads and measuring.
Offline ray copeland
Re: Norvell .061
« Reply #2 on: September 30, 2010, 04:11:24 PM »
The car engines , which were the same engine except for the head and the crank threads were the same as cox, i beleive 5-40, the airplane .061's were metric.
Re: Norvell .061
« Reply #3 on: September 30, 2010, 04:26:41 PM »
... same as cox, i believe 5-40 ...
Yes, Cox 049 threads (at least the reedies) are 5-40.  I have two bags of nicely-fitting screws to prove it.
#5 screws are nice because their nominal diameter is exactly 1/8".
Re: Norvell .061
« Reply #4 on: September 30, 2010, 07:21:50 PM »
The Norvel .049 and .061 engines have a 3mm prop shaft.  That is what screws into the prop driver/crankshaft.  It has nothing to do with any Cox engines.
Re: Norvell .061
« Reply #5 on: September 30, 2010, 07:28:06 PM »
Keith, the Norvel .061 car engines have 5-40 threads in the crank for the prop to fasten to, trust me, i have several and fly them regularly and one new in the box.  Ray
  • Proverbs
Re: Norvell .061
« Reply #6 on: October 01, 2010, 02:23:23 PM »
Looks like threaded part of prop screw is 3 mm.  But the unthreaded section steps up to 3.2 mm.
« Last Edit: October 02, 2010, 06:17:01 AM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Bill Adair
  • AMA 182626
Re: Norvell .061
« Reply #7 on: October 01, 2010, 04:34:53 PM »
Ray is correct.  H^^
Norvel .061 car engines take 5X40 prop screws.
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Re: Norvell .061
« Reply #8 on: October 03, 2010, 05:39:32 PM »
The thread is a M3.5.  Our local Ace hardware store has them.  A hardened socket headed screw works well.  The shank may mike 3.2 mm, but a standard over the counter M3.5 fits
Dave Siegler
NE9N extra class
AMA 720731
Offline Falco250
Re: Norvell .061
« Reply #9 on: October 04, 2010, 10:10:41 AM »
The Norvel airplane engines .049 and .061 use M3-0.5mm x 20mm, the 0.74 uses M4-0.7mm x 25mm, and the .15 uses M5-0.8mm x 25mm.
The Norvel Cmax car engine .061 uses 5-40 x 3/4", like Cox .049 engines.
Luciano ///
