  • July 28, 2025, 10:43:41 PM
Author Topic: Norvel Revlite  (Read 2218 times)
Offline kenneth cook
Norvel Revlite
« on: April 24, 2011, 06:01:02 PM »
              I own a Big Mig .049 Revlite version. Its just not living up to what I expected of it. I've owned the engine for 2 years and it just never seems to work consistently. I feel the pinch up top is too tight. The engine is a bit hard to start but then its all over throughout the flight. Has anyone ever tried to lap one of these style engine in. I'm convinced the fit is tight causing overheating. The engine starts to sag especially in the maneuvers. I was using a trimmed down 5x3 cox prop which surely isn't overloading the engine. I was using 10% fuel and also 35% fuels. I tried additional head gaskets thinking it may have been overcompressed as well. This just complicated starting the engine. The pinch is really harsh cold or hot . I believe the engine has about 1.5 honest hours on it. It just seems as though its not making the power like it should. I have earlier ABN versions which run 3-5 k over this one. This is the first Revlite version I owned. Initially, I filled the cylinder per instructions with castor for 24 hrs etc. I ran it in small 2 min intervals and followed the typical procedures. I'm about spent on this one. I exhausted several hours on this engine today and this is the only logical explanation I have. I switched to a APC 5.5 x2.5 on the ground it was reading 18K. On another engine same type we were seeing 23k with the same prop. That's a huge difference and mine won't even hold the 18 consistently. I would say I'm making almost Black Widow power with a bit more steadiness. This isn't all that impressive. I was wondering if any of you ever had experienced this. Ken
Offline ray copeland
Re: Norvel Revlite
« Reply #1 on: April 24, 2011, 07:14:19 PM »
Kenneth,  i would start with making sure the fuel feed is good. Vibration to the tank can be a problem, I prefer balloons. I have a twin motor plane made for two Norvels with tank mounts and one side will not run right because of vibration from that side motor mount, i have tried 3 different engines. Your prob sounds like it may be that the bushing is too tight, you may want to lap the crank to the bushing to get some more clearance, this has been a problem on some of the Norvels and some of the other hi perf 1/2a engines.  Hope you get it figured out, let us know!
Re: Norvel Revlite
« Reply #2 on: April 24, 2011, 07:44:02 PM »
Ken,
I have had success with 8 of these engines over the past several years for the several 1/2A multi-engine profile scale airplanes I have built and experience with about that many more with the engines others have used for these events.
I have had no problem with the way these engines run.  (I should mention that they all have been Big Mig versions, not the AME versions.)  Each one has had a break-in period of at least 50 minutes to 1 hour on the same fuel I intend to fly with them.
Yes, these things, out of the box, are extremely tight at TDC and are hard to hand start at first.  One thing I do and I do not believer it hurts anything  --  When I get ready to start the break-in period with the engine on a test stand hooked up to its fuel supply, I remove the Glow plug/head, put a couple of drops oil on top of the piston, then apply an electric starter, turning it over really fast by the starter in intervals of about 5 seconds.   It is remarkable the amount of fuel you will see these things pump past the piston.  You will see a significant spray coming out of the top of the cylinder.  I do not think any harm is being done as it is obvious there is plenty of lubrication for the crank shaft as well as the piston/cylinder.  I do this for about 5 or 6 spurts of 5 or 6 seconds each.  Then, put the plug on, it should start right up with the starter.  Run a total of at least 50 minute, the instruction's recommend 1 hour.  It should be easier to start, in fact hand starting is possible.
The enginewill still be tight at TDC but not like it is when you take a new one out of the box.
I have some Novel AME engines, but have not yet run them.  Apparently, these run better (as in more consistent) with some form of pressure.
Offline Larry Renger
Re: Norvel Revlite
« Reply #3 on: April 25, 2011, 08:25:23 AM »
I agree that the crankshaft fit may be too tight. With the shaft and case completely dry, spin the shaft in the case.  It should turn over several times.  If not, it is too tight.
BUT don't lap it in!  The case is aluminum, and you never quite get the abrasive out. Instead, polish the crank to size in a drill-press.  Start with 600 grit Wet or Dry sandpaper with oil.  Wrap a strip of the paper around the shaft in a "u" and pinch both ends together to provide tension.  Run the paper up and down with the drill running at moderate speed.  Clean the shaft thoroughly and check the fit.  When the shaft fits properly, final polish it with 2000 grit paper until it is mirror bright.
If that isn't your problem, it may be the fit of the piston/cylinder.  Again, don't lap it, polish it down.  Here I would start with 1000 grit as the piston is soft!  Just do the wrap thing and rotate the piston through two or three complete turns by hand.  That really ought to me enough.
Using paper instead of loose grit, the abrasive stays on the paper and doesn't get into the pores of the metal.   :!
Offline George
  • Love people, Use things.
Re: Norvel Revlite
« Reply #4 on: April 25, 2011, 09:09:44 AM »
..The engine starts to sag especially in the maneuvers.
..The pinch is really harsh cold or hot.
..I believe the engine has about 1.5 honest hours on it.
..I ran it in small 2 min intervals and followed the typical procedures.
If you bench-run it, when it starts to sag, feel the crankcase beneath the crankshaft. If it is binding, it may feel hotter than normal.
Lots of pinch usually means it is not broken-in yet. Perhaps with the extra fiddling, you may not have as much run time as you think.
Two minute intervals is not necessary. The Revlite cylinder is hard-anodized aluminum oxide coating on an aluminum cylinder, and the piston is high silicon aluminum...neither need heat cycles.
If the crank does not need polishing and the cylinder has no scoring, I think you may just need to give it more run time until it settles down.
Good luck with it.
George
George Bain
AMA 23454
Re: Norvel Revlite
« Reply #5 on: April 25, 2011, 03:40:36 PM »
        Well, thanks for all the advice. I noticed yesterday that the engine was in fact much hotter than I ever experienced a Norvel running. I can almost grab any Norvel engine as soon as it lands and its moderately warm. Don't try that with your Cox engine. I looked at the crank last night. The case shows a much more significant wear mark at the front of the case. It doesn't feel like any kind of bind though. The cylinder though has a terrible pinch at TDC. The other engine I was using as a comparison yesterday virtually has no pinch, feels like no compression, the shaft wobbles side to side. It runs like no other engine I have from start to finish. I just love it. I just can't subscribe to the fact that this engine is going to loosen on its own. It seems to me like damage to the rod or cylinder is going to result. I've seen this before in other engines where the large hole on the conrod egged out. I will try to obviously run it longer. If that doesn't work, Larry will have finally convinced me to try the AP .061. Ken
« Last Edit: April 25, 2011, 05:16:22 PM by kenneth cook »
Re: Norvel Revlite
« Reply #6 on: April 26, 2011, 07:40:16 PM »
I wouldn't expect a noticable bind.  The only way I know to check crank fit is to manually spin it in the case with both clean and dry.  It will be smooth, but stop quickly if too tight.  It will spin several times when it is right.  A friend has an AP Wasp that would burn a plug every flight.  Felt fine when turned by hand, but when disassembled, the crank was tight by the above test.  I polished it down as outlined, and we have a VERY happy motor now.
