Building Tips and technical articles. => 1/2 A building. => Topic started by: Jerry Bohn on August 03, 2007, 06:34:24 PM
What manufaturer comes close to selling an engine comparible to the Norvels?
Looking for .061 for 1/2A OT stunt.
Plan to try a Walt Musciano Stuntmaster which needs a tank mounted on the engine.
There are two that I've heard of, no experience with either--Brodak .061 and Wasp .061. Don't know if they're equal to the Norvel or not. I think the Wasp is supposed to be a clone? Somebody here will know.
--Ray
To the best of my knowledge you really don't have to have a motor with an attached tank. After all people have used Cub 'B', Wen Mac, or any of the other early motors. But to the best of my knowledge you cannot use a Norvel 049 as it does not fit the rules about porting.
Dennis
Dennis
...at the Musciano meets, you mean. "OT Stunt" was mentioned in the original post; I didn't even think about the very specialized Musciano contests. No doubt what you state is correct.
But if the intent is other more general contests, any engine will qualify. And, it's true that you don't even need a tank-mounted engine; any of the Musciano models can be modified for beam mount engines.
--Ray
I have a Wasp .061 that I actually like better than the norvel .049. It holds the needle setting better for some reason and is not as finicky. Plus the motor mounts are identical to the Norvel Big Mig. It will snap right in to the "tank" mount. You will have to lock the throttle open, I used a paperclip and wrapped it around the cylinder.
I'm running mine in a plane similar to a Lil Satan with a pressurized Sullivan Clunk tank mounted in the outboard wing
Ray, Thanks, I looked at the Brodak.061, I think thats my choice and since I'm not going to enter this plane in a contest I will use your suggested method. Your attachment shows there is room for a small 1/2 size tank.
I fly .35-.46 size planes and forgot how little fuel the 1/2A type engines use.
Thanks for posting the picture it is worth a thosand words.
Wing, who sells the Wasp and are the Norvel tanks still avaliable, very viable alternative if the tank mount is still avaliable.Thank you for the input
Jerry
I picked up my wasp in Irvine, CA on a business trip, don't remember the hobby store. As for the tanks, High Speed Hobbies in China Grove, NC had a couple the last time I was in there. They have a website just do a Google search
Hobby People sells them as does Tower by online service. The price recently rose to $45, but that is still pretty cheap. Depending on where you are, there may be Hobby People stores in your locale.
Any of the engines you mentioned seem like a LOT of engine for an 18" span hollow-log.
Good luck with it.
George
George, The mentioned engines are to make 18" hollow log stunt well.
Original engine like OK Cub.049 or Cox low end.049 type engines are for basic training, fun stuff, mabey 1 loop, mabey 45 degree wingover, thats it.
