  • July 07, 2025, 05:59:47 AM
Author Topic: Norvel parts needed...  (Read 2196 times)
« on: December 18, 2015, 09:31:00 PM »
 I've already got this posted in the Classifieds, but I'm adding it here to make sure that you 1/2Aers see it too...
  I am in need of a couple Norvel parts:
 #100151 Spinner and Screw set
 I actually only need the prop/spinner screw but these were sold as a set. If someone has just the screw that would be fine.
 #102200 Extended Fuel Tank Mount
 This is a larger tank mount that was sold as a separate option. The front portion of these is just like the stock radial (firewall) mount Big Mig tank but this version has an additional extension that passes through the firewall, roughly doubling the normal tank capacity.
 If anyone can supply either, please let me know.
 Thank you.  H^^
Re: Norvel parts needed...
« Reply #1 on: December 18, 2015, 09:54:27 PM »
You might try the Norvel website.  They have parts.
http://www.nvengines.com/
Good luck.
« Reply #2 on: December 18, 2015, 10:04:44 PM »
 Thanks Keith, I just found that out in the other post, I'll check it out.
« Reply #3 on: December 20, 2015, 03:25:58 PM »
 I just completed an online order, thanks!
