CLICK HERE--><--CLICK HERE
Cox .049 glow plugs
Started by Allen Eshleman, October 09, 2026, 09:17:45 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Allen Eshleman
I have been trying to start some .049 Cox engines. I got one started backwards. But that's not my main concern. I'm using a glow plug battery with new adapter I just got from Sullivan. The owner thought they were sold out but he found 20 more.
Real question - should these glow plugs glow bright with a glow plug battery.  All my plugs are old - some - more than 10 years. Others were bought about 6 years ago or so. Some are obviously shot. Others glow just a bit.
Should I buy new plugs?
Colin McRae
I've never seen a Cox 049 plug glow very bright, even new ones. The Cox 049 engines run best at higher nitro levels (like 25%) so more of a cold plug I believe. But not really sure.
Colin
bill bischoff
What type of battery is it? Ni-CD's and NI-MH's are only 1.2 volts, compared to a dry cell which is 1.5 volts. This is likely the cause of a dimmer glow.
Motorman
A dull red glow is all you want, maybe a little orange, don't light them up brite white.
kenneth cook
              Allen, this Sullivan adapter, is this the adapter for the hand held ni-cd to clothespin style clip? If so, the ni-cd is down on voltage as it's only 1.2 volts. The leads are very short but the wire gauge is inadequate. Yes, it works, but you may not get adequate glow on a cold start situation.
          Cox plugs can also have their coils compressed. This can happen due to a over compressed engine or running high nitro. This is risky but you can get a straight pin and carefully fully center the coils within the plug cavity. Now this can work well or it can break the coil or internal connection. In addition, insure all the coils are glowing because if any are touching, it's sketchy and it will create dull spots within the coil itself. Therefore, centering the coil and carefully separating them with a pin can insure a good glow.
          Keep in mind that adding additional head shims under the glow plug can save your plugs but it can also reduce your power a bit. One thing to bear in mind is that taking the glow head on and off is squashing the head gasket which can cause the head to loosen repeatedly during running. Insuring your glow head is flat and new uncompressed head shims will maintain a tight head. In a pinch, I've heated the shims over a open flame by holding them on a x-acto until they're glowing cherry red and let them air cool. This will put a bit of elasticity back into them.
Allen Eshleman
I have gotten an engine, black tank, with one intake to fire with the glow stick and adaptor. In fact it ran backwards for a little while, maybe 20 seconds. I'm opening the needle around three turns and squirting fuel in the side ports for priming. It fires and kicks back on my fingers indicating a flood. It bit me a couple of time. I will keep trying. This engine probably wasn't run for 15 years. Any advice. Going out to try some more.
Allen Eshleman
I tried another engine which with the glow stick started and ran almost a minute backwards. It flips very free, not labored like the first one that I described. These haven't been run for a long time. I used transmission fluid as engine run oil to loosen them up. I will keep working with the one that runs a minute or so. Maybe I have to redo the reeds agin. Any thoughts?
Colin McRae
Reed valve may be shot.
I would remove the tank, check internals and look at the health of the reed valve.
I've seen engines where the brass reed valve was cracked. I was able to get mylar replacement valves from Cox International. MECOA might also have them.
Colin
   If these engines have been sitting, the reeds are usually the main issue. Take the tanks off and clean them out. Check the little O-ring that seals the back plate to the venturi tube and make sure it's in good shape. Gskets, reeds and the O-rings are available on line from several sources but all can be made. Thew O-ring can be cut from a piece of the black tubing that comes with many Coix starting kits and were used on RTF planes. Takes some practice but just chees slice  off a piece thick enough to fill the space. Reeds can be made from any kind of mylar, and old 5" floppy discs are made from mylar and work well. I just use one of the stainless steel reeds as a pattern and cut then as needed. You can make a round punch from hard brass tubing the right size and then just have to cut the straight sides. Put the reed in the back plate or tank, and add the retainer. Then I try blowing in through the venturi and then sucking back to see if the reed seats properly. Gaskets can be from just about any tough paper you get in junkmail.Cut the big hole first, then cut the rest over size. Install on the tank or back plate, fit it up to the engine, then poke a hole in each position. I use wire that is almost the right size, then install a screw to help hold everything in place, the repeat with the other three. When finished, trim around the edges with a nice, sharp Exacto knife.
  One more thing about reeds. If your engine is pretty strong when running, the stainless reeds can get distorted. The last run of engine Cox made with the gray back plate and choke tube are pretty powerful and the ones I have been messing with will only go about 5 or 6 runs before the reed just gets too bad. I found a plastic shim stock that is .005" thick that has shown me to be the best material of all. I posted about this all in detail so you can search that up. Each type of reed has it's short comings, but this plastic shim stock has performed for me very well in hard running. And the different vintages of Cox engines require the different retainers also. Some retainers are for shallower seats and some use a plastic cage like device. Try to keep you parts seperate, and if confused or then get mixed up, the retainer should not trap the reed solidly. The reed need to flutter and move. When installed, it, should rotate and wiggle a tiny bit, otherwise it won't work I'll post some pics of the stainless reeds that I discovered distorted.
944_Jim
Mr Allen,
Dried/split fuel pickup tubes will feed until the fuel level drops below the splits. I don't remember if you changed them.
While the following is for Race Prep, it describes how to function check each part of a Babe Bee engine for success:
https://coxengines.ca/public/files/MRP.pdf
Allen Eshleman
Thanks for the advice. Looks like I'm going to have to take these engines apart.
Motorman
If they run backwards they'll run frontwards. You can get a spring starter for those engines, helps alot. You don't need to prime them much. Always prime with the exhaust port closed. When you're setting the needle valve while running, make slow movements. It takes a few seconds for the adjustment to take effect.
MM :)
