  • July 08, 2025, 07:25:43 PM
Author Topic: Norvel AME .049  (Read 1773 times)
Offline Joe Rice
Norvel AME .049
« on: April 08, 2011, 06:44:01 AM »
I built a couple of ARC Baby Clowns for a Norvel .049 that I purchased a couple of years ago.  I noticed that my engine is the "AME" version and have heard that they will not run properly without a pressure system.  Will the muffler pressure suffice?
Joe
Joe Rice
AMA 740106
Offline George
  • Love people, Use things.
Re: Norvel AME .049
« Reply #1 on: April 08, 2011, 07:42:37 AM »
Joe,
That was true of the early ABN version, I'm not sure it's true of the REVLITE version. My Big Mig CL versions came with a muffler that has a pressure nipple. If yours did not, a prop that allows good venturi velocity should help. NORVELs have a large intake for power so they must be allowed to rev-up to maintain fuel draw.
George
George Bain
AMA 23454
Offline Joe Rice
Re: Norvel AME .049
« Reply #2 on: April 08, 2011, 07:57:15 AM »
Joe,
George
George...  mine has the muffler with pressure nipple and came with a clear plastic tank mount with integral radial mount.  Seems as though I should be ok.
Joe
Joe
Joe Rice
AMA 740106
Offline ray copeland
Re: Norvel AME .049
« Reply #3 on: April 08, 2011, 09:08:02 AM »
Joe, you will definitely get better runs with muffler pressure on this engine than trying to run it without any pressure. Should be a good match for your clown. Sometimes those tank mounts are long enough to throw off the cg, on my Baby flite streak i had to add tail weight. Also there should be a diagram with the tank on how to fix the pickup for c/l or sometimes Norvel included a different pickup tube. Good luck, let us know how it does.
Offline Joe Rice
Re: Norvel AME .049
« Reply #4 on: April 08, 2011, 10:08:23 AM »
George...  My engine will be beam mounted... I will not be using the plastic tank that came with the engine, but will use a metal tank set up like the big profile planes
Joe
Joe Rice
AMA 740106
Offline kenneth cook
Re: Norvel AME .049
« Reply #5 on: April 08, 2011, 02:01:10 PM »
       Last weekend, I tried to run a new Norvel AME on a Baby Flite Streak. Well , I won't sugarcoat it for you it wouldn't work. The second I let the plane go, it would almost stall. Then the run was all over the map going lean then rich and back again. I put the engine on bladder and problem solved. I was wondering if the choke area could be shrunk down with some tubing. If the screen was removed I was going to try and find  tubing to choke it down. I was also going to try another option. I was going to take a broken APC prop, cut it apart as to only have the hub. I was going to drill the prop hole out then tap the hole  to 1/4-32 which is what I believe the Tee Dee venturi is. Then cut sand shape the hub to fit into the case opening and hold it in with a bit of JB weld. I was hoping I could then screw in the Cox Tee Dee set up with a Kirn needle and this would solve the problem. I do have currently one AME ABN engine running backplate pressure to the uniflow vent on the tank and this works well. You should try to email klondike17@juno.com I think his name is Andrew. Ask for a pressure type backplate as this would be the simplest solution. He now handles the line of the former Norvel's now known as N/V engines. Ken
Offline George
Re: Norvel AME .049
« Reply #6 on: April 08, 2011, 09:09:19 PM »
Joe
You can still use muffler pressure on the metal tank. Just run tubing from the muffler nipple to the fill line on the tank and put a plug on the tank overflow.
BTW, some of those plastic tanks were setup with the pickup tube on the bottom for RC use. I had to bend the tubing on my first one. The second one came with two tubes so you could select.
George
George Bain
AMA 23454
Offline Joe Rice
Re: Norvel AME .049
« Reply #7 on: April 11, 2011, 08:42:29 AM »
Thanks, Ken
Joe Rice
AMA 740106
