  • August 02, 2025, 04:45:57 AM
Author Topic: norvel .049,061  (Read 1584 times)
Offline bob whitney
norvel .049,061
« on: March 25, 2019, 08:56:17 AM »
the norvel muffler has a pressure nipple and my .061 runs great using it but wont run without it  hooked up
rad racer
Offline Larry Renger
Re: norvel .049,061
« Reply #1 on: March 25, 2019, 09:36:19 AM »
Which Norvel? There are two versions. The Big Mig should run fine on suction, the speed version would need pressure.
Offline kenneth cook
Re: norvel .049,061
« Reply #2 on: March 25, 2019, 02:40:22 PM »
              Bob, on the outside, they're pretty much identical. Remove the head, the Big Mig has 5 small ports in the cylinder. The AME version which is used for combat/speed has 3 large cutouts. The AME also has a larger venturi.
