Building Tips and technical articles. => 1/2 A building. => Topic started by: John Crocker on July 17, 2007, 02:01:15 PM
Just finished gluing this up. Built from memory of a Lil' Satan I had 25 years ago. Thinking about calling it "The Hornet" Ribs are 1/16" balsa, with 2 being 3/32". Wingspan is 27" with 182 sq inches of area. Bout 9 1/2 " long including the elevator, which is stitched on using Minnesota Modellers method of needle and sewing thread (Props to you MM).
Going to power with either a .049 Norvel, or a .061 Wasp, depends on which one runs better on a balloon tank. Wing covering will be red monocote with the tail being either black or corsair blue.
(http://i52.photobucket.com/albums/g3/Adduckted/Peregrine.jpg)
Where will you put the balloon?
And incidentally, you apparently have an original...I never sewed a stabilator onto booms. But thanks anyhow.
--Ray
P.S. Looks like it will go like a terror...I'd stick with the .049 in self defense!
The ballon will go in between the ribs on the outboard wing inside of a mini M&M's container. Fits perfect. Probably will go with the .049, and put the .061 on the other new plane I built as its a little heavier.
