  • August 01, 2025, 08:24:08 PM
Author Topic: new kit  (Read 3351 times)
Offline bob whitney
new kit
« on: May 24, 2019, 07:40:05 AM »
BMJR will be coming out with the Little King a profile 1/2 A full pattern  stunter right after Brodaks. I Will be flying the proto type at brodaks.
  I flew the original at joe noll but didn't have enough fuel so a new tank is in progress
rad racer
Offline Bootlegger
Re: new kit
« Reply #1 on: May 24, 2019, 09:20:47 AM »
  .....Pictures??...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline 944_Jim
Re: new kit
« Reply #2 on: May 24, 2019, 09:22:35 PM »
Specs?
This is worse than the Heinze Ketchup ads from years ago...Anticipation is making me wait!
Offline bob whitney
Re: new kit
« Reply #3 on: June 05, 2019, 09:53:11 PM »
here is the lil King and the orig Tecel
rad racer
Offline bob whitney
Re: new kit
« Reply #4 on: June 05, 2019, 09:59:25 PM »
one more shot
rad racer
Offline Jim Carter
Re: new kit
« Reply #5 on: June 06, 2019, 08:25:26 AM »
Hey Bob!  You do some pretty nice work!!  :)
Jim
Re: new kit
« Reply #6 on: June 06, 2019, 04:18:19 PM »
Mr. Rad,
Did the Tercel join the Coast Guard?
Divot McSlow
Offline bob whitney
Re: new kit
« Reply #7 on: June 06, 2019, 04:23:06 PM »
Full Bird COL
rad racer
Re: new kit
« Reply #8 on: June 10, 2019, 05:01:20 PM »
Uhhh, Captain?
Offline Larry Renger
Re: new kit
« Reply #9 on: June 10, 2019, 06:25:41 PM »
I think that Keith made to full Colonel.
The original Tercel was 10% smaller and had curved side planking. With the non availability of .049 engines and readily availability of .061 engines, the size increase is justified.
One of our more active builders has one under way. I look forward to the result. If I can keep him on track not to put in a bigger engine. So far he has proposed an 09 and a Cox Queen Bee .075 (ghastly engine). I have to remind him that .061 is the limit. He just falls in love with his latest acquisition.
Re: new kit
« Reply #10 on: June 10, 2019, 10:52:21 PM »
Larry,
I saw a partially built Tercel on the table at the field Sunday. Must be the one you are talking about. Looked pretty good so far! (I'd be tempted to put a K&B Greenhead .09 in it.)
Since Mr. Rad repainted his Tercel in a Coast Guard scheme, I figured that the plane had joined the Coast Guard. They ain't no cunnels in the Coasties; whut they got is Captains, like in the Navy. (Equivalent to a full bird...which was the rank that Bob picked out.)
Divot
