  • June 21, 2025, 02:54:51 PM
Author Topic: Flying Lines - Dacron vs. Steel Cables  (Read 2568 times)
Offline Shawn Kuntz
  • Ringmasters Forever!
« on: June 25, 2007, 09:31:47 AM »
Whats best?  I have my Brodak Baby Clown ARF with an old Cox Blackwidow .049.  I have dacron lines.  How long should they be?   25', 30' or 35'?  Steel cables for 1/2A are usually 35'.  When I was a kid I flew my Baby Flight Streak with the Blackwidow on dacron lines and it seemed to work just fine.  Any 1/2A flyers out there with any good insight?
Shawn Kuntz
Bismarck, North Dakota USA
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Flying Lines - Dacron vs. Steel Cables
« Reply #1 on: June 25, 2007, 03:26:06 PM »
Don't like Dacron, it stretches too much, but Spiderwire fishing line works well for 1/2As; I think other brands too, you just have to get the non-stretch types. .  With a BW 35' ought to be about right.
--Ray
--Ray
AMA902472
« Reply #2 on: June 25, 2007, 10:15:28 PM »
--Ray
35 feet of Spiderwire, for sure! y1
Ray, what "lbs. test" is correct??  I forgot and can't find my spool, gotta get some new!
Bill <><
    • Minnesotamodeler
« Reply #3 on: June 26, 2007, 02:16:35 AM »
Seems like it's "12 lb. test, 8 lb. dia." or something like that.
--Ray
--Ray
AMA902472
Offline Clancy Arnold
« Reply #4 on: June 26, 2007, 08:40:23 AM »
Shawn
Make sure the "Spider Wire" is woven, not monofillament.  Not all spider wire is created equal.
Read my "1/4 A flying line" report on page 2.  Also look at the clips I found.
Clancy
Clancy Arnold
U/Tronics Control
Offline John Crocker
« Reply #5 on: June 26, 2007, 09:08:03 AM »
.008 steel cables.  No stretch.  Recently proved to a buddy of mine how much it helps.  You have much less issues with the model turning in to you because of "bounce"
Offline Ralph Wenzel (d)
« Reply #6 on: June 26, 2007, 09:20:11 PM »
Not yet mentioned is the fact that the .008 steel cables will have far less wind resistance than the 12# Spyderwire. This can make a truly huge difference in performance, and will probably allow you to go to 42' lines, giving you a lot more maneuvering room.
Ralph Wenzel
AMA 495785 League City, TX
Offline Bill Heher
  • Fix-it
« Reply #7 on: June 27, 2007, 12:50:47 AM »
On the minus side for the .008 steel cables is the cost, and they are easily damaged. I do have to admit that I like the way the plane flies on them.
Bill Heher
If it's broke Fix-it
Offline George
  • Love people, Use things.
« Reply #8 on: June 27, 2007, 08:49:55 AM »
Shawn,
So there you have it. Length at 35' seems to be right for a reed valve BW.
Steel .008 cable will fly a bit better, but are harder to maintain.
Spiderwire is a close second.
Dacron works, and has been used for many years...just not a first choice by many.
Sounds like you are fairly new at flying. If so, consider the Spiderwire because of the less maintenance and handling. You need to be able to concentrate on your flying right now. Once you handle the plane without needing to concentrate so hard, switch to steel.
Of course, if you are already a proficient flier, then you need to assess your flying site. You should have a well maintained surface, free of twigs and stumps if you use steel. Steel will kink and fray easily, and must be handled with great care.
Good luck, whichever way you go.
George
George Bain
AMA 23454
