CLICK HERE--><--CLICK HERE
Need advice on a couple of found Fox engines
Started by Mark Mc, August 14, 2025, 10:16:07 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Mark Mc
I was cleaning up in the garage this morning and pulling engines out of a box.  In the box was a Fox .10 engine, along with a N.I.P. Fox .10 glow plug.  I have no experience with these, but I assume it's very low on power.  Also, does anyone know what the design purpose of the cutout in the lug beneath the needle valve was for?
And in the box was what I assume to be a Fox Rocket .09 engine.  The engine appears to have never been mounted, as there are no marks on the mounting lugs or engine case, and no gunk anywhere to show it had been run.  The Rocket has no needle in it.  Anyone know what I can do for a needle?  The good thing, if it comes to that, is that the N.I.P. glow head can be used on either engine.
Would anyone suggest something to put these in?
Motorman
You could put the .10 on a pdq Circus Prince with a 7-3 prop 52 x .012" lines. I'd get it running before you buy the kit. The lug is not cut out, it's an extra boss to be tapped for a free flight flood off holder.
The .09 nva, if you can't find a needle, you could plug the threaded end with solder and use it as a spray bar then get a remote needle off an OS LA .15. It's a unique looking engine and I think it would be cool on some kind of original semi scale profile slab wing plane with a long nose like an Airacobra. Probably would fetch a pretty penny if you sell it as new.
MM :)
