  • June 16, 2025, 09:24:26 AM
Author Topic: Just finished the Cadet  (Read 2268 times)
Offline John Castle
  • The Bent Pin
« on: January 27, 2009, 07:27:26 PM »
Just finished my first control line project since I was a teenager. I'm sure it will be heavy and fly like a rock but that's OK. This is my trainer for my larger .25 trainer. I'm actually building several to get me ready for Spring. Should be fun. :)
John Castle
McMinnville, Oregon
AMA# 589650
Offline ray copeland
Re: Just finished the Cadet
« Reply #1 on: January 27, 2009, 08:15:40 PM »
John, looks great!  Hope it flies well for you,, what size lines are you going to try?  That prop looks like a 6x3, might try a 5x3 if that is too much for the babe..  BTW  some rocks fly great!!!
Offline John Castle
  • The Bent Pin
« Reply #2 on: January 27, 2009, 09:17:58 PM »
Hmm, good call on the prop size. I will have to rummage around and see what I can find. I suppose I will use the standard 35' nylon lines and see what happens.
John Castle
McMinnville, Oregon
AMA# 589650
  • Gravitywell
« Reply #3 on: January 27, 2009, 09:39:15 PM »
That is a very cute (errrrr  I mean handsome!) little plane....I love it!  It may be just the angle of the photo, but your motor looks like it has 1 or 2 degrees of up thrust.  Maybe give that a check and if it does, just put a washer under the top screws.  Very nice little ship there. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline George
  • Love people, Use things.
« Reply #4 on: January 28, 2009, 01:37:19 PM »
Ships are usually referred to as "she" so cute is good.  ;D
George
George Bain
AMA 23454
Offline John Castle
  • The Bent Pin
« Reply #5 on: January 28, 2009, 01:45:40 PM »
BTW the plans for this plane are at the bottom of this page:  http://www.smallflyingarts.com/Free_Plans/free_plans.htm
John Castle
McMinnville, Oregon
AMA# 589650
Offline goozgog
« Reply #6 on: January 28, 2009, 02:57:41 PM »
Hello John,
 The plane looks great! Just some thoughts regarding
weight.
I know those wheels! (I think) Mine are very heavy.
A set of modern foamies might be better.
The wire lead outs are easy to work with but they're
on the inboard side and need to be balanced with
extra tip weight. I run my Spectra lines right up to
the bellcrank and leave them tied to the plane with
the lines wound around the handle.
It's a cumbersome way to store lines but light and
simple.
I've been using 8# Spectra fishing line and I'm
very happy with it, even in the pouring rain
after several loops.
Since you own a Baby Bee, and if you need
to practice your inverted flying, you might
want to try an indestructable Mann Winn trainer.
The free plans are available at
www.balsabeavers.ca
Look under the "Newcomers/Plans" heading. The idea
is to have the Bee mounted upright when the
plane is inverted. Launch the plane inverted
flying clock wise. Most people seem
to get the knack after seven or eight trys.
I've taught three people inverted flying in
one morning.
Sorry to be a Know-It All.  y1
Good luck and
welcome back!
Morgan
« Last Edit: February 06, 2009, 06:37:16 PM by goozgog »
Keith Morgan
