  • June 18, 2025, 12:59:02 AM
Author Topic: Spinner for 1/2a Nobler  (Read 4338 times)
Offline Allan Perret
  • Proverbs
« on: October 01, 2010, 09:44:34 AM »
Several years ago I wanted to build a 1/2A Nobler.  Took the plans from Brodak Original Nobler kit and had them reduced to 70%.  The spinner at .7 was just a shade under 1.25".  I could not locate a 1.25 spinner that I was happy with so thats as far as the project got.   Now there are 1" aluminum spinners available from Brodak and also Lee Machine Shop.  Anybody ever use either of those ?   I am going to use the 1" even thought it will be slightly under scale..
At 70% the span is 35.25" and the area is 265".  I know this is pushing the limit of my Norvell .061, but I also have a Norvell .074 for plan B.  I will build nose with interchangable mount system for either engine.   What is a good target weight for this set-up, I really want it to work with the .061 and not have to go to the .074 ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Jim Thomerson
Re: Spinner for 1/2a Nobler
« Reply #1 on: October 01, 2010, 12:46:23 PM »
There are 1 1/8 plastic spinners with metal backplate available, maybe from Hobby People.  These were a Cox design which Cox did not produce.   Maybe someone else can tell you more.   I'd say you could go up to 12 oz and still be OK.  Lighter is always better with small airplanes.
  • Proverbs
« Reply #2 on: October 01, 2010, 01:54:45 PM »
Went to the Hobby People site, did not see any 1 1/8" spinners.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline John Crocker
« Reply #3 on: October 01, 2010, 01:55:29 PM »
If you want it to stunt it will need to be 14 oz or less in my experience.  You can fly more weight than that with the .061, but not stunt reliably, they tend to get REAL slack on the lines above 30-400 degs.  I'd shoot for something under 12 oz
Offline john vlna
« Reply #4 on: October 01, 2010, 02:15:43 PM »
Try MECOA, they advertise a 1.25" that fits a COX .049. See their ad at http://mecoa.com/cb/spinners.htm
  • Proverbs
« Reply #5 on: October 01, 2010, 04:44:03 PM »
Norvell .061 has a 3mm prop screw, I think Cox uses a 5-40, right ??
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: October 01, 2010, 04:59:19 PM »
Yes.  Just a tad bigger at 3.2mm.  You can either squint and pretend that 8mil off center isn't a problem, you can wrap the screw with some shim stock, or, well, something.
  • Proverbs
« Reply #7 on: October 01, 2010, 05:37:44 PM »
For me, 8 mill off center at 20K+ is a problem.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #8 on: October 01, 2010, 05:53:58 PM »
Picky.
So wrap the screw with the right amount of brass shim stock to bring it up to diameter.
Online Larry Renger
« Reply #9 on: October 01, 2010, 07:09:26 PM »
I have run the Brodak small spinners and they work great. Very good quality and mine ran perfectly true at over 20K.
  • Proverbs
« Reply #10 on: October 02, 2010, 06:21:32 AM »
Would the 1/2A Nobler be legal for either Classic or N30 ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #11 on: October 02, 2010, 10:35:48 AM »
George drew up 1/2A plans in two sizes for his Nobler, Magnum and Agwagon.  Several sets were sold at one of George's auctions at a VSC.  I don't have copies.
« Reply #12 on: October 02, 2010, 11:17:53 AM »
Hi Allan,
Not so sure that *your* 1/2A Nobler would be technically legal, actually it wouldn't be..  If George drew 1/2A plans, then *those* would be.  All depends on how anal the CD/ED (and other competitors) are.
Online Larry Renger
« Reply #13 on: October 02, 2010, 06:49:28 PM »
I hope the drool doesn't short out my keyboard.  WHERE can I lay my hands on the Aldrich plans?  I would love to fly legal classic 1/2As (besides my own pitiful Tech Terror).
Offline Jay
  • 1 Cross +3 Nails= 4 Given
« Reply #14 on: October 06, 2010, 08:03:15 PM »
From what I understand the Stork is a 1/2 A Nobler.  I seen a kit of one by Golden State Models just last weekend in Lansing at the cancelled Tour De Michigan.  It was a profile with working flaps.  Sure was glad i left the wallet home or it might of follwed me.
Jay
My religion consists of a humble admiration of the illimitable superior spirit who reveals himself in the slight details we are able to perceive with our frail and feeble mind.
Albert Einstein
  278622
« Reply #15 on: October 11, 2010, 01:17:32 AM »
Jay
Hi Jay!
I have a Spitfire from Golden State Models.  It was a companion model to the Stork.  There were one or two more.
