  • July 08, 2025, 12:47:59 AM
Author Topic: My 1/2A with flaps.  (Read 4799 times)
Offline Duke.Johnson
My 1/2A with flaps.
« on: July 04, 2013, 12:40:38 PM »
Someone started a thread on a 1/2A slab wing with flaps.  I couldn't find that one, but thought I would share my new 1/2A with flaps.  Have not flown it yet, maybe today.
Offline Larry Renger
Re: My 1/2A with flaps.
« Reply #1 on: July 04, 2013, 02:31:18 PM »
That looks like fun!  H^^
Offline Bill Johnson
« Reply #2 on: July 06, 2013, 09:51:08 AM »
That's very interesting, Duke. What' the base airplane?
Best Regards,
AMA 350715
« Reply #3 on: July 06, 2013, 10:07:55 AM »
Bill-This is very close to the drawings, called the Wing Master. I flew it yesterday, it flies pretty good ( lazy 8's, loops, inverted, and a bad wing over).
« Reply #4 on: July 06, 2013, 02:47:22 PM »
Well it sure is a sharp looking airplane. Glad it flies good!
Best Regards,
AMA 350715
« Reply #5 on: July 06, 2013, 06:58:14 PM »
Thanks.  I did crash it a little. There's a couple weak points that should be corrected, like where the flaps go through the fuse.
« Reply #6 on: July 06, 2013, 08:24:32 PM »
Hi Duke,
I would like to see one built with the same wing area, but no flaps, to see what difference flaps make in that configuration.
BIG Bear
RNMM/AMM
« Reply #7 on: July 07, 2013, 10:34:18 AM »
I might do that, I would like to remake this one and then the flapless
Offline john vlna
« Reply #8 on: July 07, 2013, 03:12:09 PM »
My brother and kids built the Wingmaster backin the 80's.  They flew quite well as I recall. I've never tried flaps on these little 1/2A planes, but yours makes me want to try one
Offline don Burke
« Reply #9 on: July 08, 2013, 07:51:55 AM »
Hi Duke,
BIG Bear
RNMM/AMM
Fix the flaps with the flap pushrod taped to the fuselage, then use a pushrod straight to the elevator, can be done between flights at the field.
don Burke AMA 843
Menifee, CA
« Reply #10 on: July 08, 2013, 08:06:46 PM »
Where can you get plans for one? I've searched quite a bit but cannot find any references to and airplane, just a shotgun n~
Best Regards,
AMA 350715
« Reply #11 on: July 08, 2013, 09:44:28 PM »
So this is what I know about the Wing Master. I have drawings that are about 24"x18", with blue print over blue 1" grid lines by Jm Petro.  It might be Jim, but the I don't see the (i) to make it Jim.  They are marked May, 1981 and in the bottom right under the title block there's the number 377.  This said, just in case someone remembers seeing drawings like this in a magazine.
Offline john vlna
« Reply #12 on: July 09, 2013, 08:10:30 AM »
Duke
The Wingmaster was published in Aug 1982 in Model Aviation, Jim Petro designer. Plans are available from AMA and the article is online in the MA Archives.
« Reply #13 on: July 09, 2013, 11:30:26 AM »
There you go guys.  thanks John
« Reply #14 on: July 09, 2013, 04:22:15 PM »
Thanks, guys! I'll get a set of plans. Sometimes it takes me some time to get projects going and this will be no different as the wife and I are going house-hunting in Huntsville next week, but I pretty much always follow through. My longest running project to date is a 1903A3 Springfield I bought in 1992. Bubba had it for years, apparently. Finally finished the restoration  in 2010.
Best Regards,
AMA 350715
Online Curare
« Reply #15 on: July 09, 2013, 05:06:03 PM »
Looks good! Mine was a barrel of laughs until I started to do squares, there's just no time to react!
Might have to build another  n~
Greg Kowalski
AUS 36694
« Reply #16 on: July 09, 2013, 08:26:04 PM »
Other than building the nose out of balsa and ply, the only other thing I would change would be where the flaps go through the fuse.  It's to weak.  Almost every time I take it out the fuse breaks at the opening for the flaps.  I would either make the fuse out of 1/8" balsa and two pieces 1/16" ply or not have the flaps go through the fuse (which would be the lightest I think).  You could put a small piece of ply on both sides of the fuse and join the flaps with a wire.  I just put it back together after flying it tonight.  This time I pushed two toothpicks in for strength.
Online Curare
« Reply #17 on: July 10, 2013, 07:39:08 PM »
I fitted a half moon of 1/64" ply over the cutout to strengthen it on mine. It didn't break there, but did break the wings off a half dozen times.
Greg Kowalski
AUS 36694
Jim Roselle
« Reply #18 on: July 10, 2013, 10:46:22 PM »
Man, it's comforting to hear that I'm not the only one who spends as much time fixing as I do flying. ;D
Jim
« Reply #19 on: July 11, 2013, 11:31:24 AM »
Jim
 **) **) **) Oh yeah, not funny!  I have it all back together now, just waiting for the wind to stop.
